Automatically add Storm Discharge Points to End of Culvert line features?
1867
03-20-2014 11:08 AM
RobertThomson
Occasional Contributor II
Looking at the LGM sample I see many culverts defined as stand alone with a storm discharge at each end.  I have many driveway culverts like this in our model and would hate to have to do this by hand.  Is there any way to automatically do this?
Possibly some kind of code that would cycle through each selected culvert, check the end to see if it already has a storm discharge or other object attached, and if not insert a storm discharge.
MikeMillerGIS
Esri Frequent Contributor
The select edge by junction count tool may help you select these, then maybe use the Attribute Assistant to get the X,Y coordinate at the end of the culverts.  Then export this to excel, make an x,y event layer and load to your point layer.
X Coordinate rule:
http://resources.arcgis.com/en/help/localgovernment/10.1/index.html#/X_coordinate/028s000000mm000000...
