Can the Public Notification tool be used against Portal for ArcGIS?
1300
6
08-18-2016 11:38 AM
JacobBoyle
Occasional Contributor III
As stated, Can this application be configured to use Portal With SAML \ Oauth?
I'd like to deploy this using our Portal.
JakeSkinner
Esri Esteemed Contributor
Hi Jacob,
Yes, you should be able to configure this application with Portal using SAML.  The application will still be using feature/map services whether it's using AGOL, ArcGIS Server, or Portal.
JacobBoyle
When I set my Portal URLs for the app, I get a blank map when I load the app in a browser.  Also, I would expect a place to set my portal URL, app secret and app ID to register with Oauth.  Are my assumptions wrong there?
JakeSkinner
I haven'te tested this app with Portal, yet, but I beileve you will need to update the proxy.config to supply the clientId and app secret.  Ex:
<serverUrl url="http://route.arcgis.com/arcgis/rest/" matchAll="true"
          clientId="APP ID"
          clientSecret="APP SECRET"
          rateLimit="50"
          rateLimitPeriod="10"
></serverUrl>
JacobBoyle
Thanks, figured the proxy folder was only if you needed to use a proxy.
JacobBoyle
Ok, gave this a shot, and reloaded the app.  It didn't help.
JacobBoyle
I've opened a ticket with Esri Support, I'll post the results here as well for the community's benefit.
