Help with geocoding
6002
14
05-21-2015 09:05 AM
ELTerrell
I just added a spreadsheet of 7 different points. I used GPS Visualizer: Free geocoders: Convert addresses to GPS coordinates to geocode my addresses (city halls).  4 of the 7 when placed on the map, were mapped correctly. The other three were waaaay north of the county I'm mapping.  I used Geographic Coordinate System:   Name: GCS_WGS_1984  to add my xy data.  Does anyone have any suggestions as to how/why this happened and how I can fix it?  Thanks so much.
JoeBorgione
Ever check here for NC GIS data?  Maybe 'rolling your own' locator is a better way to go....
Just a thought.
ELTerrell
Haven't checked out this site yet.  How do you roll your own?
StevenGraf1
You will need some type of reference data such as a road centerline file with address ranges.  Once you have a source data file you can follow these instructions.
If all these points are in the same county or counties, it might be your best bet to see if your local county or city GIS department has those layers.  That would be your most accurate data.  They like to strip information out when they send data to a data repository.
ArcGIS Help 10.1
Steven.
JoeBorgione
Check this link out:  Geocoding – Some learning resources
https://community.esri.com/docs/DOC-6206#comment-14223
It's an awesome resource!
ELTerrell
I ended up using this site Free Online Non-Parsed Postal Address Geocoding (texas a&m) and was able to finally get gis to recognize the coordinates.  Funny, even when using the same coordinates for 'go to xy' feature it came up with a different location than uploading that address in a spreadsheet.
