Hello all.
Per the subject, I'm getting errors when running the NEAREST_FEATURE and the NEAREST_FEATURE_ATTRIBUTES methods.
The exact error message is "Object reference not set to an instance of an object." What I'm trying to do is to pull attributes off the street centerline into a new address point. And what's interesting is there are 3 of us pulling from this same DynamicValue table, and the other 2 machines work properly; it is only mine that has this issue.
So, the exact log entries:
Row Info
Row Number 11
TableName: AddressPoint
FieldName:
ValueInfo: RoadCenterline|ROADPREDIR,ROADNAME,ROADTYPE|ROADPREDIR,ROADNAME,ROADTYPE|350
ValueMethod: NEAREST_FEATURE_ATTRIBUTES
On Create: 1
On Change: 0
Checking for Subtype Restriction
Field is not specified, empty, or set for all.
Trying NEAREST_FEATURE_ATTRIBUTES
Looking for layer: RoadCenterline
RoadCenterline layer Found: RoadCenterline
Checking Field Mapping
Field Mapping verified
Searching for Nearest Feature
ERROR: NEAREST_FEATURE_ATTRIBUTES
Finished: NEAREST_FEATURE_ATTRIBUTES
Row Info
Row Number 13
FieldName: ROADSEGMENTID
ValueInfo: RoadCenterline|SEGMENTID|350
On Create: 1
On Change: 0
Field Name: RoadSegmentID was found at index: 30
Trying: NEAREST_FEATURE
Searching the layer
ERROR: NEAREST_FEATURE: Object reference not set to an instance of an object.
Any suggestion on troubleshooting and the like will be greatly appreciated!
