I used the 'Import Using Geoprocessing' tool. I had the database set up
with the domains already so it just had to add the feature classes. This
will take longer to run but tells you exactly what the error is.
On Settlement_Srf it failed:
ZA340_LGF_GRP* are integer fields with default 'No Information' on cell
e186. Needs to be changed in many places.
F_CODE - AL022_PPLX default value is too long and I think should be AL022,
had to fix this in the corresponding domain too.
On StructurePnt the HD320* fields are integers but the default values are
'No Information'
I ran out of time to check the last feature class tonight.
