Swift Layer List Examples
643
04-06-2023 05:36 AM
Justin_Greco
Occasional Contributor II
Are there any examples of building a layer list from a web map, particularly one with group layers?  I am get the layers from map.operationalLayers to show in a List view, but am struggling with getting the sublayer for group layers to appear as children, since the .  The layer list is not part of the toolkit, are there plans to have add one in the future?
Justin_Greco
Was a bit easier than I had thought.  Here is a code sample:
import SwiftUI
import ArcGIS
struct LayerView: View {
    var map: Map
    var body: some View {
        List {
            ForEach(map.operationalLayers, id:\.self) { layer in
                SublayerView(layer: layer)
        .onAppear {
            //make all group layers visible by default
            map.operationalLayers.forEach { layer in
                if (layer.subLayerContents.count > 0) {
                    layer.isVisible = true
                    layer.subLayerContents.forEach { sublayer in
                        if (sublayer.subLayerContents.count > 0) {
                            sublayer.isVisible = true
struct SublayerView: View {
    var layer: Layer
    @State private var expanded: Bool = false
            DisclosureGroup(layer.name, isExpanded: $expanded) {
                ForEach(layer.subLayerContents.reversed(), id:\.self.name) {
                    sublayer in
                        SublayerView(layer: sublayer as! Layer)
                    } else {
                        Toggle(isOn: Binding<Bool>(get: {sublayer.isVisible}, set: {sublayer.isVisible = $0
                            Text(sublayer.name)
        } else {
            Toggle(isOn: Binding<Bool>(get: {layer.isVisible}, set: {layer.isVisible = $0})) {
                Text(layer.name)
Justin_Greco
import SwiftUI
import ArcGIS
    var map: Map
        List {
        .onAppear {
    var layer: Layer
                    sublayer in
                    } else {
                            Text(sublayer.name)
        } else {
                Text(layer.name)
MarkDostal
Hello! Thank you for your question and I'm glad you found a solution. A legend or "layers list" is something that we will be implementing in the Swift Toolkit at some point, but there's no firm release date yet.
In the meantime, you solution looks good! You can also take a look at the v100.15 Toolkit's LegendViewController, and the actual code.
There are a few things in that code that may be of interest, depending on your requirements:
- Including base maps in the layers list
- Ensuring the Map and Layers are loaded prior to displaying the list
- Displaying symbol swatches for layers
- Hiding/showing scale-dependent layers depending on map scale (applicable primarily for Legends).
Nice work! If you have any more questions, please reach out!
Mark
Justin_Greco
Thank you Mark.  I was able to incorporate a legend and a opacity slider.  Here is some code in case anyone else is trying to do the same.
import SwiftUI
import ArcGIS
class LegendSwatch: ObservableObject, Identifiable , Hashable {
    static func == (lhs: LegendSwatch, rhs: LegendSwatch) -> Bool {
        return lhs.label == rhs.label && lhs.swatch == rhs.swatch
    @Published var label: String
    @Published var swatch: UIImage
    init(label: String, swatch: UIImage) {
        self.label = label
        self.swatch = swatch
    func hash(into hasher: inout Hasher) {
        hasher.combine(label)
        hasher.combine(swatch)
struct LayerInfoView: View {
    @State var layer: Layer
    @State private var swatches: [LegendSwatch] = []
        ScrollView {
            VStack {
                Text("Opacity")
                Slider(value: $layer.opacity, in: 0...1, step: 0.1) {
               minimumValueLabel: {
                   Text("0%")
               } maximumValueLabel: {
                   Text("100%")
                ForEach(swatches, id: \.self) { swatch in
                    HStack {
                        Image(uiImage: swatch.swatch)
                        Text(swatch.label)
        .task {
            let infos: [LegendInfo] = try! await layer.legendInfos
            infos.forEach { info in
                Task {
                    let swatch = try? await info.symbol?.makeSwatch(scale: 1.0)
                    self.swatches.append(LegendSwatch(label: info.name, swatch: swatch!))
