dissolve - xytolerance
1829
8
07-31-2012 05:29 AM
by Anonymous User
Not applicable
Original User: Sester
hi,
i want to dissolve polylines, however i notice, that some of them are merged into a single polyline, some are merged into multi-polylines.
when checking the difference, i noticed that the common points between them differ, e.g. 0.2 cm when it was merged into a single polyline and 11 cm when it produced multi-polylines.
i tried to use the XYTolerance setting in order to als "snap" the 11 cm,
arcpy.env.XYTolerance = "5 meters"
however, the parameter setting does not seem to have an influence.
any ideas?
-monika
MathewCoyle
Did you set the multi_part parameter to SINGLE_PART?
by Anonymous User
Not applicable
i just tried it: now it creates two separate lines (instead of merging them into one multipart-object)
-moni
MathewCoyle
Try doing a repair geometry on your source. Do they have Z values that might put them outside the tolerance? I'm not sure how Z values interact with XY tolerance actually.
by Anonymous User
Not applicable
hmm - no, it is only a 2d-geometry. also, i just tried to repair the data before.
unfortunately, no change!
i attached my small data set and the python script - perhaps this triggers some ideas?
-monika
MathewCoyle
You don't have a projection. That has to be set to work with tolerances.
by Anonymous User
Not applicable
thank you very much, mathew, for your patience!
however ... i tried it and still the same result.
-moni
MathewCoyle
Try setting your tolerance down to 1 Meter, that worked for me, not sure why.
I was having problems with the 5 Meter tolerance as well, I'd think about filing a bug report with Esri.
Edit: Also you need to export to a geodatabase. Shapefiles weren't working for this either.
by Anonymous User
Not applicable
thank you!
at least, there seems to be a solution - however a little erratic ....
kind regards
-monika
