field calculator
3419
5
11-05-2011 09:10 AM
by Anonymous User
Not applicable
Original User: luke.kaim
I need some help with this code. I need to be able to change the units of X and Y within model builder or python. Therefore, I can not use calculate geometry. How do I convert the X and Y locations into decimal degrees using the field calculator? The below code is not working. I want to find X and Y location of points and then be able to change the units of the points from meters to decimal degrees. I need to be able to automate this process. Please help. I know I can use the function "Add X,Y" but that does not allow one to change units. How do I change units after I have the two columns?
X-coordinate of a point
Dim dblX As Double
Dim pPoint As IPoint
Set pPoint = [Shape]
dblX = pPoint.X
Y-coordinate of a point
Dim dblY As Double
dblY = pPoint.Y
"Shape and length properties of the geometry field can be modified with unit types expressed with an @ sign".
Thank you,
Luke Kaim
Thank you
Luke Kaim (SIE)
Lucas.Kaim@maine.edu
(914)263-7866
by Anonymous User
Not applicable
Original User: Hornbydd
Why don't you project your original data into lat/long then join that table back to your original data and pass over the XY coordinates using the calculate tool?
JakeSkinner
Esri Esteemed Contributor
You can create a new field of type text and then run the following within the field calculator:
Pre-logic Script Code
def dd2DMS(dd):
    if dd > 0:
        deg = int(dd)
        min = int((dd-deg) * 60)
        sec = (((dd - deg) * 60) - min) * 60
        return str(deg) + " " + str(min) + "' " + "%.4f" % sec + '"'
    if dd < 0:
        deg = int(dd)
        min = int((dd-deg) * 60 * -1)
        sec = (((dd - deg) * 60 * -1) - min) * 60
[FIELDNAME] =
dd2DMS(!POINT_X!)
by Anonymous User
Not applicable
Thank you so much JSkinn3.
This is heading in the right direction. I am using utm though so my original field is in meters. I need to go from meters to decimal degrees. The code you wrote I believe goes from dd to degrees minutes seconds. What would the code look like from meters to dd? I also tried your code and I could not get it to work even when I used dd as my input.
Thank you,
Luke Kaim
JakeSkinner
Hi Lucas,
Sorry, I mis-read your previous post.  You can update from meters to DD using the 'arcpy.UpdateCursor' function.  With cursors, you have the ability to set a working coordinate system.  Ex:
import arcpy
from arcpy import env
env.workspace = r"C:\temp\python\test.gdb"
fc = "Cities_Meters"
prj = r"C:\Program Files (x86)\ArcGIS\Desktop10.0\Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj"
spatRef = arcpy.SpatialReference(prj)
env.geographicTransformations = "NAD_1983_To_WGS_1984_1"
rows = arcpy.UpdateCursor(fc, "", spatRef)
for row in rows:
    geom = row.shape
    row.POINT_X = geom.centroid.X
    row.POINT_Y = geom.centroid.Y
    rows.updateRow(row)
del row, rows
Since I am switching datums from NAD_83 to WGS_84, I needed to apply a geographic transformation.  You will need to update 'row.POINT_X' and 'row.POINT_Y' with the fields you want to store the DD values.
Also, here is how you can do this using the field calculator:
def func():
  arcpy.env.geographicTransformations = "NAD_1983_To_WGS_1984_1"
  for row in rows:
    geom = row.shape
    return geom.centroid.X
func()
With the field calculator you will have to run it for each individual field, and change 'geom.centroid.X' to 'geom.centroid.Y' for the appropriate field.
by Anonymous User
Not applicable
Thank you so much JSkinn3. I totally owe you a beer or a two.
Luke
