Portal for Arcgis error when adding layer to map
490
06-12-2017 09:04 AM
Sean_Bailey
Hello, has anyone come across an issue where when you attempt to add a layer to a map in Portal for ArcGIS you get an error that says "the layer, layername, cannot be added to the map"?  I am using ArcGIS Datastore as the registered database in ArcGIS Server manager.
