import arcpy, os, sys # test version for cursor type (data access module available @ 10.1 +) ver = arcpy.GetInstallInfo()['Version'] dataAccess = False if ver != '10.0': dataAccess = True def Message(msg): print str(msg) arcpy.AddMessage(str(msg)) return def create_field_name(fc, new_field): '''Return a valid field name that does not exist in fc and that is based on new_field. fc: feature class, feature layer, table, or table view new_field: new field name, will be altered if field already exists Example: >>> fc = 'c:\\testing.gdb\\ne_110m_admin_0_countries' >>> createFieldName(fc, 'NEWCOL') # NEWCOL >>> createFieldName(fc, 'Shape') # Shape_1 ''' # if fc is a table view or a feature layer, some fields may be hidden; # grab the data source to make sure all columns are examined fc = arcpy.Describe(fc).catalogPath new_field = arcpy.ValidateFieldName(new_field, fc) # maximum length of the new field name maxlen = 64 dtype = arcpy.Describe(fc).dataType if dtype.lower() in ('dbasetable', 'shapefile'): maxlen = 10 # field list fields = [f.name.lower() for f in arcpy.ListFields(fc)] # see if field already exists if new_field.lower() in fields: count = 1 while new_field.lower() in fields: if count > 1000: raise bmiError('Maximum number of iterations reached in uniqueFieldName.') if len(new_field) > maxlen: ind = maxlen - (1 + len(str(count))) new_field = '{0}_{1}'.format(new_field[:ind], count) count += 1 else: new_field = '{0}_{1}'.format(new_field, count) count += 1 return new_field def AttributeUpdate(source_table, in_field, update_fields, join_table, join_key, join_values): # Check input parameters if not arcpy.Exists(source_table): print '"%s" not found!\nPlease verify that full path of table exists' %source_table sys.exit() if not arcpy.Exists(join_table): print '"%s" not found!\nPlease verify that full path of table exists' %join_table sys.exit() if in_field not in [f.name for f in arcpy.ListFields(source_table)]: print "'%s' not found in \"%s\"" %(in_field,os.path.basename(source_table)) sys.exit() if join_key not in [f.name for f in arcpy.ListFields(join_table)]: print "'%s' not found in \"%s\"" %(join_key,os.path.basename(join_table)) sys.exit() for fld in update_fields: if fld not in [f.name for f in arcpy.ListFields(source_table)]: print "'%s' not found in \"%s\"" %(fld,os.path.basename(source_table)) print 'Please verify that field names match in "%s"' %os.path.basename(source_table) sys.exit() for fldb in join_values: if fldb not in [f.name for f in arcpy.ListFields(join_table)]: print "'%s' not found in \"%s\"" %(fldb,os.path.basename(join_table)) print 'Please verify that field names match in "%s"' %os.path.basename(join_table) sys.exit() if not isinstance(update_fields, list): update_fields = list(update_fields) if not isinstance(join_values, list): join_values = list(join_values) # Make sure there is matching number of join and update fields if len(update_fields) == len(join_values): up_flds_list = [f for f in arcpy.ListFields(source_table) if f.name in update_fields] up_flds_dict = dict([(f.name,f.type) for f in up_flds_list]) jn_flds_list = [f for f in arcpy.ListFields(join_table) if f.name in join_values] jn_flds_dict = dict([(f.name,f.type) for f in jn_flds_list]) types_dict = {'String': str, 'Single':float, 'Double':float, 'Integer':long, 'SmallInteger':int} path_dict = {} if dataAccess: # Create Dictionary join_values.insert(0, join_key) with arcpy.da.SearchCursor(join_table, join_values) as srows: for srow in srows: path_dict[srow[0]] = tuple(srow for i in range(len(join_values[1:]))) # Update Cursor update_index = list(range(len(update_fields))) row_index = list(x+1 for x in update_index) update_fields.insert(0, in_field) with arcpy.da.UpdateCursor(source_table, update_fields) as urows: for row in urows: if row[0] in path_dict: allVals =[path_dict[row[0]] for i in update_index] for r,v in zip(row_index, allVals): row= v urows.updateRow(row) print 'Fields in "%s" updated successfully' %(os.path.basename(source_table)) else: # version 10.0 srows = arcpy.SearchCursor(join_table) for row in srows: path_dict[row.getValue(join_key)] = tuple(row.getValue(i) for i in join_values) del srows # Update Cursor rows = arcpy.UpdateCursor(source_table) for row in rows: theVal = row.getValue(in_field) if theVal in path_dict: for i in range(len(update_fields)): try: theType = types_dict[jn_flds_dict[join_fields]] row.setValue(update_fields,theType(path_dict[theVal])) except: row.setValue(update_fields, path_dict[theVal]) rows.updateRow(row) del rows else: print 'ERROR: Number of update fields and value fields does not match' return def CopyFields(source_table, in_field, join_table, join_key, join_values=[]): ''' Copies field(s) from one table to another source_table: table in which to add new fields in_field: a field that has common values to a field in the join_table. think of this as a "join_field" join_table: table with fields to add to source_table join_key: field to match values of the "in_field" join_values: fields to add to source_table (list) ''' # Get Catalog path (for feature layers and table views) cat_path = arcpy.Describe(source_table).catalogPath # Find out if source table is NULLABLE if not os.path.splitext(cat_path)[1] in ['.dbf','.shp']: nullable = 'NULLABLE' else: nullable = 'NON_NULLABLE' # Add fields to be copied update_fields = [] join_list = arcpy.ListFields(join_table) for field in join_list: ftype = field.type name = field.name length = field.length pres = field.precision scale = field.scale alias = field.aliasName domain = field.domain for fldb in join_values: if fldb == name: name = create_field_name(source_table, fldb) arcpy.AddField_management(source_table,name,ftype,pres,scale,length,alias,nullable,'',domain) Message("Added '%s' field to \"%s\"" %(name, os.path.basename(source_table))) update_fields.insert(join_values.index(fldb), name.encode('utf-8')) # update new fields path_dict = {} if dataAccess: # Create Dictionary join_values.insert(0, join_key) with arcpy.da.SearchCursor(join_table, join_values) as srows: for srow in srows: path_dict[srow[0]] = tuple(srow for i in range(1,len(join_values))) # Update Cursor update_index = list(range(len(update_fields))) row_index = list(x+1 for x in update_index) update_fields.insert(0, in_field) with arcpy.da.UpdateCursor(source_table, update_fields) as urows: for row in urows: if row[0] in path_dict: try: allVals =[path_dict[row[0]] for i in update_index] for r,v in zip(row_index, allVals): row = v urows.updateRow(row) except: pass else: # version 10.0 rows = arcpy.SearchCursor(join_table) for row in rows: path_dict[row.getValue(join_key)] = tuple(row.getValue(join_values) for i in range(len(join_values))) del rows # Update Cursor rows = arcpy.UpdateCursor(source_table) for row in rows: theVal = row.getValue(in_field) if theVal in path_dict: try: for i in range(len(update_fields)): row.setValue(update_fields,path_dict[theVal]) rows.updateRow(row) except: pass del rows Message('Fields in "%s" updated successfully' %(os.path.basename(source_table))) return if __name__ == '__main__': source = r'C:\TEMP\PermitTest\test.gdb\Permits' join = r'C:\TEMP\PermitTest\test.gdb\orono_test' fields = ['BLDG_NUM', 'SALE_DATE', 'APPLICANT'] # Run it CopyFields(source, 'PID_NO', join, 'PID_NO', fields)
Caleb,
I've been using your updated module but can't get it to work -
I'm using it as part of a larger project to run statistics...basically I'm doing some frequency analysis and then want to join those to a single feature class and calculate over the rows.
I'm using the following syntax:
AttributeUpdate(target_table, 'XYZ', ['POS'], posoutfq, 'XYZ', ['FREQUENCY'])
Where target_table is my...well... target table
XYZ is the field in the target table to be joined on
POS is the field I want populated
posoutfq is the geodatabase table with the frequency stats in it
XYZ is the common table in posoutfq
FREQUENCY contains long integers that I need to populate POS with.
Generally everything works fine until it gets to urows.updateRow(row) in the AttributeUpdate function. Then I get a runtime error stating that the "value type is incompatible with the field type [POS]." But both POS and FREQUENCY are "long" data types. FREQUENCY contains some null values, but POS allows null values.
But when I join them manually in ArcMap and calculate over the values (using the python calculator) they update just fine.
So I'm guessing that somehow, the module is either reading the wrong field or reading one of the two fields as a string, or something like that.
Any ideas or assistance would be appreciated - and your work on this is already much appreciated... this will save me enormous amounts of time on what will be a regular process!
Hi Eric,
Glad to see you are getting some use out of this. It looks like I have an updated version (as of 6 months ago) so maybe replace the function with the code below:
def AttributeUpdate(source_table, in_field, update_fields, join_table, join_key, join_values): ''' Copies field(s) from one table to another using using field matching lists source_table: table in which to add new fields in_field: a field that has common values to a field in the join_table. think of this as a "join_field" update_fields: fields to be updated (must be in same order as join_values) join_table: table with fields to add to source_table join_key: field to match values of the "in_field" join_values: fields to add to source_table (list) ''' # test version for cursor type (data access module available @ 10.1 +) ver = arcpy.GetInstallInfo()['Version'] if ver != '10.0': dataAccess = True else: dataAccess = False # Check input parameters if not isinstance(update_fields, list): update_fields = list(update_fields) if not isinstance(join_values, list): join_values = list(join_values) if not arcpy.Exists(source_table): print '"%s" not found!\nPlease verify that full path of table exists' %source_table sys.exit() if not arcpy.Exists(join_table): print '"%s" not found!\nPlease verify that full path of table exists' %join_table sys.exit() source_fields = arcpy.ListFields(source_table) join_fields = arcpy.ListFields(join_table) for fld in [in_field] + update_fields: if fld not in [f.name for f in source_fields]: print "'%s' not found in \"%s\"" %(fld,os.path.basename(source_table)) print 'Please verify that field names match in "%s"' %os.path.basename(source_table) sys.exit() for fldb in [join_key] + join_values: if fldb not in [f.name for f in join_fields]: print "'%s' not found in \"%s\"" %(fldb,os.path.basename(join_table)) print 'Please verify that field names match in "%s"' %os.path.basename(join_table) sys.exit() # Make sure there is matching number of join and update fields if len(update_fields) == len(join_values): up_flds_list = [f for f in arcpy.ListFields(source_table) if f.name in update_fields] up_flds_dict = dict([(f.name,f.type) for f in up_flds_list]) jn_flds_list = [f for f in arcpy.ListFields(join_table) if f.name in join_values] jn_flds_dict = dict([(f.name,f.type) for f in jn_flds_list]) types_dict = {'String': str, 'Single':float, 'Double':float, 'Integer':long, 'SmallInteger':int} path_dict = {} if dataAccess: # Create Dictionary join_values2 = join_values[:] join_values2.insert(0, join_key) with arcpy.da.SearchCursor(join_table, join_values2) as srows: for srow in srows: path_dict[srow[0]] = srow[1:] # Update Cursor update_fields2 = update_fields[:] update_fields2.insert(0, in_field) with arcpy.da.UpdateCursor(source_table, update_fields2) as urows: for row in urows: if row[0] in path_dict: try: row[1:] = path_dict[row[0]] urows.updateRow(row) except: pass else: # version 10.0 srows = arcpy.SearchCursor(join_table) for row in srows: value = row.getValue(join_key) path_dict[value] = tuple(row.getValue(i) for i in join_values) del srows # Update Cursor rows = arcpy.UpdateCursor(source_table) for row in rows: theVal = row.getValue(in_field) if theVal in path_dict: for i in range(len(update_fields)): try: theType = types_dict[jn_flds_dict[join_fields]] row.setValue(update_fields,theType(path_dict[theVal])) rows.updateRow(row) except: try: row.setValue(update_fields, path_dict[theVal]) rows.updateRow(row) except: pass del rows del path_dict print 'Fields in "%s" updated successfully' %(os.path.basename(source_table)) else: print 'ERROR: Number of update fields and value fields does not match' return
That error is strange though, you should never get an error that says the value is incompatible with the field type if both fields are long. I haven't looked at this code in a while, but a lot of it looks pretty sloppy to me. Maybe I will go back and do a full rewrite when I have time.
Hi Chris,
I just found this thread, i hope its still active. I am faced with a task to do a spatial join of points to polygon and read from the points fc, the rows with a null street name and copy values from 6 fields in the join table to the original feature class. My code looks like this right now:
arcpy.env.workspace = r"path"
GaR = "points"
Parcel = "Parcels"
Join_table = "Join_table"
arcpy.MakeFeatureLayer_management("points", GaR)
arcpy.MakeFeatureLayer_management("Parcels", Parcel)
arcpy.SpatialJoin_analysis (GFR, Parcel, Join_table, "", "", "", "WITHIN")
where = "STREET_NAME" + " IS NULL"
with arcpy.da.SearchCursor(GFR, ["STREET_NAME"], where) as cursor:
for row in cursor:
CopyFields (GaR, "ID", Join_table, "ID", fields)
Join_table has ID, Name, street, location, state and zip and i am trying to copy these into the fields in GaR and then delete the Join-table.
Looking forward to hearing from you
Ayo
