Arc Hydro Construct Depression Hierarchy error
475
05-09-2022 03:39 PM
Labels (2)
by Anonymous User
Not applicable
Attempting to run the Construct Depression Hierachy and get an error I do not understand. Have tried using a raw DEM and a smoothed DEM from the Smooth Depression DEM tool, results in same error.
Using the latest ArcHydro version 2.9.27 with ArcGIS Pro 2.9.2. I think the Python environment is ok but not much to go by to know for certain.
The only error message is:
('line 426', 'c:\\program files\\arcgis\\pro\\Resources\\ArcToolbox\\Scripts\\ArcHydro\\constructdepressionhierarchy.py', "AttributeError: 'GPEnvironment' object has no attribute 'outwriteOutput'")
It looks like that error message means the dataset already exists there and your geoprocessing environment setting doesn't have an attribute that looks like a typo of "overwriteOutput"
by Anonymous User
Not applicable
It was not an existing dataset issue, so no idea what was wrong.
In the last couple of weeks there has been an update to ArcGIS Pro ( and a separate update to ArcHydro. Something within the updates seems to have fixed whatever the problem was.
