My most recent discovery is more generally related to geoprocessing and is not specific to Arc Hydro. However, since Arc Hydro is heavy on geoprocessing, I wanted to post this here.
My latest Arc Hydro project had ArcMap freezing up when saving and at other times. I'd have to wait forever or, out of impatient frustration, I would "X" out and/or cancel it using Task Manager. Then I heard about something in the geoprocessing options that seems to have put and end to that!
This seems to make saving much, much faster and I haven't had it crash yet.
Hope this tip helps!
Mark
I am using arc hydro 10.1 and there are some solutions to these error which works for me
- define workspace location and processing extent in c drive
- Whenever you have to use arc hydro, always define a geodatabase then start using the tool
- always delete the temp files.
May be this will help.
Hello!
I have a problem when calculating the Longest Flowpath using HEC-GeoHMS.
It turns out that the program starts to compile, stays for more than 20 minutes calculating, after that the program is closed, I open it again and all the progress of the Longest flowpath calculation is lost.
I have tried deleting the temporary files, changing the location of the files and everything said above.
I need if someone can help me with this problem please.
This is an excellent Arc Hydro thread that I've depended on throughout my Arc Hydro experience.
Has anyone had success using Arc Hydro for ArcGIS Pro for stormwater workflows? I'm trying to take into consideration streets and drainage networks for watershed delineation, like I've done in ArcMap 10.5 and 10.6. Unfortunately, I'm encountering a lot of problems including ERROR 999999 and Failed to Execute EucAllocation.
I’ve tried re-organizing my data and troubleshooting different ways as well per other stratgies I've learned with ArcMap but to no avail. Perhaps they still need to work out some bugs or revert back to Target Location folders?
You help's much appreciated!
#archydrotools, #archydro drainage delineation, #archydro tools
Sorry. I haven't had the opportunity to use ArcGIS Pro.
Mark
Hi all,
I am having difficulty running Evaluate Depressions on a 1600x2500 grid in 32-bit integer centimetres. I have also tried 16-bit but it still hangs at the same point (Computing drainage area for depressions...).
It runs fine on floating point grid but it is slow (4 hours) so I was hoping that it would be faster for integer grids.
I would like to know:
If anyone has successfully Evaluated Depressions on an integer grid of such a size?
Has anyone noticed significant performance improvement on integer grids compared to floating point?
Thanks! Garret
I haven't used that tool. Running the project on the local C: drive does speed processing up quite a bit. If you aren't doing that, you may want to try it.
Best,
Mark
Hi Mark,
Just closing off this issue. "Evaluate Depressions" hadn't been 'migrated' to Python. It has been now thanks to Christine in ESRI and python version works much faster now even with float raster. See the thread.
Garret
I felt that after so much research and frustration, I needed to share my findings regarding an error that kept showing when I used the Sink Evaluation tool (see image)
It turns out that my system decimal symbol was set to "," instead of "." which caused the Field Calculator to interrupt the process and trigger the COM component error. This might be more useful for the French community but anyhow, I think it's good to be put out there.
My team has been working with ArcHydro tools for a long while, and our team leader, a black belt in Python scripting, created a script that would do what GeoHMS did, so that our engineers wouldn't have to go through all of the Arc Pre-Processing steps individually. Lately we've been getting "MemoryError" issues, even on small basins. The only things that have changed in the script are minor tweaks to make the process faster.
On my computer, the process seems to get stuck at the Compute Basins, Reaches, and Nodes section, but the errors come at other places on other machines.
I've set extents, cleared the temp folder, and turned off background geoprocessing, but still am getting the error. Any ideas on where to go next?
You've been a great help on here, so I thought I'd ask the expert before calling Esri!
Annina
