Failed to import RAS data!
6510
12-10-2012 08:38 PM
BikashSherchan
I am using ArcGIS 9.3 and HEC-RAS 4.1.0 to model flood inundation with HEC-GeoRAS to export/import files. I have completed HEC-RAS analysis and tried to import the result into ArcGIS environment to see the flood inundation area. But my repeated attempts are failed with the following error messages:
  • Failed to import RAS data!
  • Failed to read RAS data!
  • Object reference not set to an instance of an object
Any suggestions regarding this problem are highly appreciated.
Regards
Bikash
[ATTACH=CONFIG]19843[/ATTACH]
MattMead
Set it to the classic import method instead of "new" and it should work.
RaphaëlGallay
You have to define the spatial reference of your Grid. Then try to execute a new analysis (RAS Mapping/Layer Setup).
