Aligning objects to Pipes
1021
05-16-2017 03:14 AM
LouiseMarnoch
How can I set my valves and other objects 90 degrees to the pipeline so they are represented like this : -----|----
 Currently they look like this:
MikeMillerGIS
Esri Frequent Contributor
I would suggest using the Attribute Assistant Junction Rotate method
All methods - Attribute Assistant | ArcGIS Solutions
SSMIC3038
Occasional Contributor III
Yup, that's what I use.
