I am brand new to Attribute Assistant and am running into some issues. We are going to be using the Attribute Assistant to update fields with the User Name (for who edited a feature) and the Timestamp (for when the feature was edited). We have been asked that when three different attribute fields (within the same table) are updated that each updated attribute field populates who updated that field and when it was updated. Because the data we are going to be updating is going to be done in stages, there is a chance that one attribute field will be updated at a time. For example, we will be looking at stormwater pipes. For the first run through someone will be updating the ownership of the pipe and we want to capture who updated it and when. The second run through will be updating pipe material and we want to know who updated this and when, etc. The issue I am having in my test file is that when I update just the ownership field, the who and when is updated for ownership AND pipe material.
I created a test table and a DynamicValue table in a test geodatabase just to make sure I knew what I was doing before I started working with the real data. So in my test table I have a field for the Point of Interest and a field for the Number of Parking Spots. I also have fields for "Who created POI" (for field editor username), "Who updated Parking Spots" (for field editor username), "POIupdated" (for timestamp when Point of Interest field is updated), and "ParkSpaceupdated" (for timestamp when Number of Parking Spots is updated).
The issue that I am having is that whenever someone goes in and updates the Point of Interest, the who updated fields for POI and Parking Spots BOTH update instead of only the "Who created POI" field updating. The same thing happens with my timestamp fields. When I change the "Number of Parking Spots", the timestamp for the Parking Spots AND the Point of Interest change. I don't know if it's because I have written the Value Info incorrectly, or if I have to change it to an expression or what the problem is. Any advice, tips, or help would be greatly appreciated. I have attached my test DynamicValue table for reference.
Thanks!!
