Operable Status of a Valve
946
08-17-2012 06:42 AM
TomasRiesco
Hellow everyone,
Cant get the operable status of a valve working with the infrastructure editing and reporting toolbar. Any help??
TomasRiesco
FYI. This is how the code should look like in order to work if anyone needs it. make sure you Add Operable field in your valves and source layer. Apply the enabled domain.
<add key="TraceIsolation_Source_FeatureLayer" value="wWTP" />
    <!-- The layer used to stop the trace. Used by the Iso Trace and the Summary Iso trace and the Toggle operable status-->
    <add key="TraceIsolation_Valve_FeatureLayer" value="wSystemValve|wControlValve" />
    <!-- The field in the valve layer to determine the if the valve is operable 0/false or 1/true are valid values.
    If a valve is non operable it is skipped by the trace used by the Iso Trace and the Summary Iso trace and the toggle valve status tool
    <add key="TraceIsolation_Operable_Field_Valves" value="Operable" />
    <add key="TraceIsolation_Operable_Field_Sources" value="Operable" />
    <add key="TraceIsolation_Operable_Values" value="0|1" />
    <!-- you need to use character codes for reserved xml characters, less then, greater then, etc-->
    <add key="TraceIsolation_Valve_AddSQL" value="" />
    <!-- Option to clear existing Flags before running the Isolation trace-->
    <add key="TraceIsolation_ClearFlagsOnClick" value="true" />
MikeMillerGIS
Esri Frequent Contributor
Are you using your own data model?  Did you update the configuration file?  Are you editing?
TomasRiesco
Yes I did all that. I have it working now. Thanks for your help.
TomasRiesco
BELHADJMOHAMED
Hi everyone, I use the local government data of ESRI and everything goes well except for the tool named "change operable status of a valve" I got a message please look at the joined file. ThanksValve_Status message
