Water Inventory Report - Script Errors
2747
08-10-2015 07:28 AM
RobertThomson
Occasional Contributor II
I'm running the supplied script from the Windows Command Line and are receiving these errors:
********************Script Started********************
Script started at 2015-08-10 10:54:40
-----Portal Credentials-----
Credentials loaded
-----Portal Credentials complete-----
-----Data Prep Section Starting-----
-----Data Prep Section complete, time to complete: 0:00:02.049000-----
-----Report Section Starting-----
Processing reports in config ./configs/WaterInventoryReports.json, starting at: 2015-08-10 10:54:42
error in function: classified_pivot
error on line: line 1269
error in file name: T:\GIS\ESRI\WaterInventoryReportsA4W\Application\solutionreporttools\reporttools.py
with error message:
with arcpy message: Failed to execute. Parameters are not valid.
ERROR 000824: The tool is not licensed.
Failed to execute (Frequency).
Script complete, time to complete: 0:00:52.842000
###############Script Completed#################
Any ideas?
MikeMillerGIS
Esri Frequent Contributor
The report tools require an Advance license of ArcGIS Desktop.  I just checked the solution page and we have the license level listed incorrectly.  We will get the help updated in the next release.
MikeMillerGIS
RobertThomson
I was certain the previous version of this worked on Standard?  I do in fact still the maps on our ArcGIS Online account.
Could you make the next release work with Standard?  That would open it up to a lot more people.
MikeMillerGIS
We use a number of processes that require Advance.  One of those, Pivot, we have used since the beginning.  I do not believe these ever worked with Standard.
