Create two widget-controllers in a theme
1011
02-21-2018 08:46 AM
Helenpeng
New Contributor III
I would like to create a theme that has two widget-controllers so some widgets can be in a header area and some widgets in a sidebar area. My two widget-controllers (as the HeaderController and SidebarController) can individually work well. When I tried to merge them together, it appears the problem of double the existing widgets (See the screenshot). I wonder if it is possible to create two widget-controllers in one theme. If so, how to make two controllers contain different widgets within two panels.
To make the desired layout, I also tried to customize Tab Theme and moved Search widget in the header area, which is getting what we want (See the second screenshot attached). But I cannot add more widgets in the header area. I think it would be nice to add two widget-controllers in a theme to make the desire layout. I wonder if this would be possible.
I attach my zip files for HeaderController and SidebarController.
Helen
MarkCooper5
Occasional Contributor II
Hi
I want to do the same thing as you. Did you ever find out if it were possible?
Thanks
Mark
Helenpeng
New Contributor III
Mark,
It has not been figured out yet. I see the similar question in the other community(below). No answer either.
If you find out the solution, please share with us. Thanks.
https://community.esri.com/groups/web-app-builder-custom-widgets
JingchaoZhou
New Contributor II
Hi Helen,
Any follow ups on this topic? I am facing the same issues.
Thanks.
