Dart Theme - Simple Customization / Add Logo
2244
10-20-2016 02:49 PM
BrianCollins
I'd like to add our agency logo to the Dart Controller in the Dart Theme. I've attached a screen capture of the conceptual layout. I'm not sure where to add the content to specify an image to appear on the left side of the controller. I've accomplished the task by modifying the code of an application after it has been saved, but I'd like to configure the logo to be include by default in WAB.
I can easily modify the css and json to shift the existing component postions...just not sure how to add additional content.
Thanks for any suggestions. 🙂
RobertScheitlin__GISP
Brain,
   Not sure if you completed this yet or not but I finally found some time to make this change to the Dart theme. I did not do any mobile testing though.
The attached file has the there files I had to edit and the edits are commented
BrianCollins
I should also add that I'd like the logo to minimize and/or disappear when you click the ellipsis at the top of the dart controller bar.
Brain,
BrianCollins
Thanks Robert, this is great! I'm working with Esri Developer Support to make some additional customization to our WAB environment. Your code sample is very helpful.
TonyBedogne
New Contributor II
Hello
This is an old thread and is kind working for me.  My logo is VERY small.  How to I change the size of the logo.  I have tried modifying the .css but i can not jet it working.
Please help
