Enhanced Coordinate widget
8680
16
02-20-2015 10:31 AM
Hey everybody,
Brandon Keinath‌ asked if it would be possible to display the current scale of your map within the widget in this thread. I took the challenge and added it to the ESRI coordinate widget. Just in case anybody else finds this useful!
Let me know if there is anything else that might make sense to add and I see what I can do.
In the future I'll probably clean up the code a little bit.
Tim
Comments
AveKargaja
Nice work
But I have a question. How is it possible to display space instead of comma (the thousand separator) in the current scale number? For example instead of "1 : 2,000" I would like to see the scale number as "1 : 2 000"
Ramon
TimWitt2
Ramon Reimets,
this should work for you: Dropbox - Coordinate.zip
Tim
AveKargaja
Thank You Tim, this is what I was looking for
Ramon
AndrewWallick2
New Contributor III
Tim,
This widget seems really helpful. Unfortunately, though, I can't get it to work. I downloaded the folder and replaced the current "Coordinate" folder in arcgis-web-appbuilder-1.1\client\stemapp\widgets with your folder, but when I loaded Web AppBuilder, nothing had changed. I restarted the builder several times to make sure it had restarted but it still didn't show up. It just look like normal.
Do you know what could be the issue?
TimWitt2
Andrew Wallick
Try the following and see if that works. Create a Web App and then go to the following folder
arcgis-web-appbuilder-1.1\server\apps\Here the number of your Web App\widgets
And replace the Coordinate folder with my folder and see if it works.
Tim
AndrewWallick2
New Contributor III
Thank you, that worked! Do you know why it would work there but not in the Builder?
CourtneyBarbee
New Contributor II
Tim,
Thanks for making this widget! There's one thing that I've noticed when I use it and not sure if it's just me or how to fix it... Above where the scale displays - I think it's supposed to show the coordinates for where your mouse is - but it just says 'loading...' and never changes. I am using a state plane coordinate system. Any advice?
Thanks again, I appreciate any help.
TimWitt2
Courtney Barbee​ do you use a State Plane basemap?
CourtneyBarbee
New Contributor II
Yes I am using a State Plane basemap
TimWitt2
What version of WebApp builder are you using and what is the WKID of your basemap?
I tried to reproduce the issue but I couldn't.
CourtneyBarbee
New Contributor II
I'm on version 1.2 and the WKID is 2277. Thanks for looking into it
TimWitt2
Does the ESRI widget without my modification work for you?
I tried a State Plane basemap and I can't reproduce the issue.
See pic
When you open up the developer window in chrome does it give you any errors?
CourtneyBarbee
New Contributor II
The ESRI widget does work.
I think I just figured out what it was because now it is working... I went into the configure window and it had my correct State Plane showing, but when I actually clicked edit the WKID,  the number it showed wasn't right which is a bit strange. See below.
From here I just put in the correct WKID and it is working now. I actually never went in to edit/look at the WKID before since the Output Coordinate system displaying was the right one. A pretty easy fix! Thanks so much for taking the time to help me out.. I appreciate it
TimWitt2
I never went into the config either until you had the problem. Glad I could help!
AdamGebhart
Occasional Contributor III
Hi Tim Witt‌.  Should this work well when more than one coordinate system is added to the widget?  I have added it to a Developer 2.5 app and it loads without any problems.  Noticing that ESRI has changed the CSS and images between versions 1.x and 2.5, I have updated your CSS to match the current default WAB 2.5 Coordinate CSS, etc. I can also get that to update without problem.
In the first image you can see what that looks like when the widget is not in use.  That looks good.  The second image shows how the widget area expands when I hover over the up arrow in the lower right corner.  Again, that looks good.  The problem is as soon as I move the mouse to actually select GCS_WGS_1984, the widget collapses and I can't select anything.   Even if I slowly move the mouse to the far right (second image) and move up at the up arrow, the widget still collapses.
Are you aware of any issues like this or do you have an idea of what changes I can make to get it to work?
Regarding the CSS updates - the only values I've changed are .jimu-widget-coordinate .coordinate-background and .jimu-widget-coordinate .coordinate-info font size from 11 to 14.
-Adam
AbdulmoneamKharsa
New Contributor II
This is a very helpful widget.However, if you can modify the widget to accept the PRJ file (i.e. Well Known Text WKTX) beside WKID as an optional in the widget configuration.
Version history
Last update:
‎02-20-2015 10:31 AM
Updated by:
Contributors
