Enhanced Search Widget Version 2.23.1 - 11/22/22
547855
2821
07-14-2014 03:57 PM
Live Preview Site
Web AppBuilder for ArcGIS | Help - Enhanced Search widget
List of the latest enhancements and changes:
  1. Fixed issue with Spatial Relationship settings
Older enhancements or changes
Check the "Older enhancements or changes.txt" in the download for a complete list.
Older Versions
Last 2.21 version
Last 2.17 version
Last 2.13 version
Last 2.12 version
Last 2.11 version
Last 2.9 version
Last 2.7 version
Last 2.6 version
Last 2.5 version
Comments
Alexander_DanielMena
New Contributor III
Hi Robert Scheitlin, GISP, thank you for excellent work with this widget.
I'm working about to show relate table that were loaded in the web map. I achieved load the tables over the widget Attribute Table but at moment of filter the result with the objectid (or attribute relation between tables) not working, then the tables show all records. I use "partsObj" expression and then setFilterObj over the activeTable.
Could you check why the filter not working on active table?
Thank you so much.
* Consultar Tablas relacionadas
_showDetailsinAttributeTable: function (arg) {
debugger;
alert('Consultando tablas relacionadas...' + arg.codigopredio);
this.operLayerInfos.getTableInfoArray().forEach(lang.hitch(this, function(layerInfo) {
console.log(layerInfo.title, layerInfo.id);
layerInfo.setFilter("CODIGO_PREDIO='" + arg.codigopredio +"'");
this._openResultInAttributeTable(layerInfo);
if (this.wManager) {
var widgetCfg = this._getWidgetConfig('AttributeTable');
if(widgetCfg){
var attWidget = this.wManager.getWidgetByLabel(widgetCfg.label);
if(attWidget){
this.wManager.openWidget(attWidget);
var partsObj = {
"expr": "CODIGO_PREDIO='" + arg.codigopredio +"'",
"parts": []
console.info(attWidget);
var activeTable = attWidget._activeTable;
activeTable.setFilterObj(partsObj);
activeTable.refresh();
RobertScheitlin__GISP
Alexander,
Seems like its a timing issue then. You need to ensure that AT widget is loaded and opened and then set the active table using the _openResultInAttributeTable function and wait to be sure the AT widget is ready (I would use a 1 second timeout) then apply the filter to the activeTable. In you eSearch code I open the AT widget and ensure that the AT Widget is visible by doing these lines:
attWidget._openTable().then(lang.hitch(this, this._openResultInAttributeTable, currentLayer));
New Contributor III
rscheitlin, my WAB version is 2.1
Originally, I used the function "attWidget._tableFunctionController.getActiveTable();" to get the active table but the function "_tableFunctionController" not exist into the object attWidget, then I use "attWidget._activeTable" but I don't know if that is Ok because the filter is not applied. I'm sure that the AT is loaded and opened because the query open the table when found results.
setTimeout(lang.hitch(this, function(){
if(widgetCfg){
if(attWidget){
attWidget._openTable().then(lang.hitch(this, function (){
var partsObj = {
"parts": []
//var activeTable = attWidget._tableFunctionController.getActiveTable();
}), 5000);
Thank you so much.
RodWoodfordOld
Occasional Contributor III
Hi Robert,
When do you think you will have a fix for the date issue when exporting to CSV? Any info would be great.
Rod
Rod,
   I have that and some other fixes and enhancements done and started on relates again. I have to much more work to do with relates so I will roll that part back and release 2.1.1 this week.
RodWoodfordOld
cheers Robert, your a good man. The esearch widget is a fantastic tool.
Rod
ScottMoore__Olympia_
Hi Robert,
I have downloaded the latest version of eSearch and I am trying to use the export to csv functionality.  I bring in the eSearch widget, and even using one of the demo layers like Lousiville Zoning, and enabling CSV export, when I query by Shape, and try to export the results to CSV, I always get an empty CSV.  I may be doing something silly, but any thoughts you have would be appreciated.
Scott
Scott,
   When I tested on my live preview site it worked fine with by Shape. I do know about a issue with dates exported in the CSV but nothing about getting a blank CSV. I will be releasing a 2.1.1 version this week to fix the CSV Date issue.
I downloaded WAB 2.1 fresh and copied in the latest eSearch and configured it and it did not work. I will try again on another machine.
RodWoodfordOld
Hi Robert,
Thanks for the 2.1.1 update. I have noticed the REMOVE RESULT option doesn't seem to work anymore. Can you please test to confirm. See screen shot.
Rod
Rod,
   Thanks for reporting that. For some reason I commented out line 88 of the List.js (and I don't know why). I will re-upload 2.1.1 with that fix but it would probably be just as easy for you to un-comment line 88 on your end.
RodWoodfordOld
Hi Robert,
Is it possible to clear date search fields when clicking the CLEAR FIELDS button. I keep getting conflicts with default date settings and other field searching. See screen shot below. Users are getting frustrated needing to clear this field manually every time they search. Any advice would be great.
cheers
Rod,
  OK that will take some change to a couple of files:
Widget.js
      clearFields: function () {
        if(this.AttributeLayerIndex || this.AttributeLayerIndex === 0){
          var exInd = this.expressIndex || 0;
          if(exInd > 0){
            this.onAttributeLayerExpressionChange(this.expressIndex);
          }else{
            this.onAttributeLayerChange(this.AttributeLayerIndex);
          var valuesObj = lang.clone(this.config.layers[this.AttributeLayerIndex].expressions.expression[exInd].values.value);
          console.info(valuesObj);
          array.map(valuesObj, lang.hitch(this, function(valObj){
            if(valObj.operation.toLowerCase().indexOf('date') > -1){
              if(valObj.valueObj.hasOwnProperty('value')){
                valObj.valueObj.value = "";
              if(valObj.valueObj.hasOwnProperty('value1')){
                valObj.valueObj.value1 = "";
              if(valObj.valueObj.hasOwnProperty('value2')){
                valObj.valueObj.value2 = "";
              this.paramsDijit.setSingleParamValues(valuesObj, "");
SingleParameter.js
      setValueObj:function(valueObj){
        //console.info(valueObj.valueObj);
        var shortType = this.value.fieldObj.shortType;
        if(shortType === 'string' || this.numberwithin){
          if(this._type === 1){
            this.stringTextBox.set('value',valueObj.valueObj.value);
          else if(this._type === 2){
            var stringSelectedItems = array.filter(this.stringCodedValuesFS.store.data, lang.hitch(this, function(item) {
              return item.code === valueObj.valueObj.value;
            if (stringSelectedItems.length > 0) {
              this.stringCodedValuesFS.set('value', stringSelectedItems[0].id);
        else if(shortType === 'number'){
            this.numberTextBox.set('value', valueObj.valueObj.value);
            var numSelectedItems = array.filter(this.numberCodedValuesFS.store, lang.hitch(this, function(item) {
            if (numSelectedItems.length > 0) {
              this.numberCodedValuesFS.set('value', numSelectedItems[0].id);
          else if(this._type === 3){
            this.numberTextBox1.set('value', valueObj.valueObj.value1);
            this.numberTextBox2.set('value', valueObj.valueObj.value2);
        else if(shortType === 'date'){
            if(valueObj.valueObj.value === ""){
              this.dateTextBox.set('value', null);
            }else{
              this.dateTextBox.set('value', new Date(valueObj.valueObj.value));
              this.dateTextBox1.set('value', null);
              this.dateTextBox2.set('value', null);
            }else{
              this.dateTextBox1.set('value', new Date(valueObj.valueObj.value1));
              this.dateTextBox2.set('value', new Date(valueObj.valueObj.value2));
ChadRicks
New Contributor III
Hey Robert. This is probably a stupid question but my brain isn't working today. I am setting predefined fields for a value but the value has commas. like "Mission Dependent, Not Critical" and the esearch is separating text by the comma. What do i put in the predefined field to not separate on that comma?
Thanks
RodWoodfordOld
Hi Robert,
Thanks for the code and prompt reply, it works perfectly clearing date fields, in fact all fields. Could this be added as an enhancement option.
cheers
Rod,
   That will be added to the next release.
Chad,
  I had something in place for this in the past but future enhancements to userlists broke that. If you start a new thread asking about this then I will be able attach the updated files and instructions.
RodWoodfordOld
You might need to include the predefined option as well.
Rod,
??? Chad and I were talking about predefined user lists.
RodWoodfordOld
Yes sorry, Chad followed on from the Clear date issue post. To follow on from your enhancement inclusion post re CLEARING DATE fields, the predefined option also needs to be included as it doesn't clear.
Rod,
   OK, I forgot that the predefined list creates a drop down that can be cleared.
JamesMarok1
New Contributor III
I'm sorry if I missed this but there so many posts in this thread now.
Is there a way to get wildcards into the [Value] for the SQL query
I have two records for Owners
Brown  Mark
Brown  Mark / Cindy
I want the users to be able to enter Brown Cind and find the second record, but currently with the %[Value]% structure you would have to enter Brown Mark to find that record as well as the first one. ( I do know if I enter Brown%Cind, I will get the record I want but layperson users not going to enter that is the search box)
Basically I need the spaces in the [Value] to be recognized as wildcards but I know of no way to do that.
James,
   No there is no option for that. You have contains (%[value]%), starts with ([value]%) or ends with (%[value]).
JamesMarok1
New Contributor III
😞 very disappointing my Silverlight site has that functionality, but now we would have to take a step backward for our search tool.
James,
   I would like to know how the silverlight app handled that situation.
JamesMarok1
New Contributor III
I actually have a Javascript mobile site that development was abandoned on in favor of moving to the WAB, that does that as well, My next attempt is trying to engineer that into a new Search widget, but I am sure your much better than me at that.
James,
   If you share the code that is working for that I will evaluate it and see if it is something I would be willing to add to the eSearch.
JamesMarok1
New Contributor III
More than happy too, its a functionality that is very useful to us.
SimpleSearch
James,
   Thanks for sharing. It looks like the way you are accomplishing what you want is by building a SQL string that does a contains query on each word entered. The resulting SQL statement would look like "NAME LIKE %Brown% AND NAME LIKE %Cindy%". I will have to think about the implications of this.
AndrewNiederhauser1
New Contributor III
Hi Robert,
I'm using your Enhanced Search widget 2.1. Great widget! I'm setting up a search on various feature classes with less than 100 records and field type: Short integer. I've setup many other searches and they work great. However, I've tried to setup a query with Year Constructed is then select from unique values. In the preview screen and deployed apps, the short integer search on Year Constructed does not seem to be working. Just keeps saying it's retrieving unique values but never returns anything. Other queries using "is" and unique values works great and returns in seconds but they haven't used short integer fields. Any idea what could be causing this hangup?
screenshot from eSearch setup
WAB esearch 2.1 result when setting up query
 screen shot of field properties
Andrew,
   What Version of ArcGIS Server are you using?
AndrewNiederhauser1
New Contributor III
Robert,
10.3.1
Andrew
Andrew,
   I have tested on two different map services (10.3.1) now using a short Integer field and I have no issue using unique (one of the services had 15K records and another 76K). Can you check your browsers web console for errors?
New Contributor III
Hi Robert,
I detected that attributes type Date when set it to "Ask for values"  and users no entered a value, the function "buildWhereClause" fail if value is null. Furthermore, when I use the condition "between", the function "_onRangeDateBlur" on SingleParameter.js fail if values are nulls.
I use WAB 2.1 and eSearch version 2.1.
Thanks, I appreciate your help.
Alexander,
   2.1 version of the eSearch code does not look like that for the buildWhereClause function. You must be using older code.
In True 2.1 version code that error would not occur due to proper handling of the possible null value:
New Contributor III
Thank you Robert, You are right. I will try to move it to last version.
Regards.
AnninaHirschi_Wyss1
Dear Robert,
I don't know if this is a Server configuration/version issue or if eSearch could handle that.
I have a public service Layer: Village (ID: 0) running on an ArcGIS Server 10.2.x outside of the AGOL subscription used for WAB. I use it in the eSearch widget (only in the search, not added to the AGOL webmap).
The issue with this Layer: I cannot change the order of the fields displayed in the result list and pop up. I use the eSearch pop up for it. In the config file, the order as I want it is there, but it seems to have no effect.
I cannot add sort fields for the result list either.
For services running in AGOL and available in the map, there is no such problem.
Thanks a lot for your help,
Annina
Annina,
The issue is the older version of ArcGIS Server. Even though I can requesting the fields in a certain order they are not return by the server in that order. I will have the eSearch work around this in the 2.1.2 version.
AndrewNiederhauser1
New Contributor III
Robert,
I tested multiple services with layers containing number fields (type: short, long, or double). For number fields with null values, the unique values search function would not return values. I'm using Server 10.3.1 and eSearch 2.1.1.
Andrew
BL
New Contributor II
Are there any future plans for this enhanced search widget to work with vector tiles? Thanks!
Thomas,
   Vector tiles are main for display advantages, and would have little if anything to do with attribute query. I could possibly impact spatial/graphical searches, but right now I have not immediate plans.
Andrew,
   I must have something to due with the null values then as I mention in my earlier post I tested numeric fields with no issue. What about my latter portion of my response to you? Do you see any errors in the browsers web console?
CristiDelgado
New Contributor II
Hi Robert, my enhanced search widget was working but now I cannot access the configure dialog window in the builder (version 2.1) to reconfigure my existing widget or create a new one.  Here's the console error msg (also inserted as image):
init.js:35 GET http://cobmapv2.berkeley.root:3344/webappbuilder/stemapp/jimu.js/dijit/LayerFieldChooser.js?wab_dv=2... q.injectUrl @ init.js:35require.injectUrl @ env.js:288qa @ init.js:32a @ init.js:10(anonymous function) @ init.js:19ja @ init.js:28na @ init.js:19(anonymous function) @ init.js:33a @ init.js:10Xa @ init.js:33s @ init.js:30(anonymous function) @ init.js:35
init.js:36 Error: scriptError(…)(anonymous function) @ init.js:36(anonymous function) @ init.js:14a @ init.js:10q.signal @ init.js:14(anonymous function) @ init.js:35
init.js:37 src: dojoLoader
init.js:37 info: ["/webappbuilder/stemapp/jimu.js/dijit/LayerFieldChooser.js?wab_dv=2.1", Event]
init.js:37 .
I hope you can help me. Esri support was not able to help me.
Cristi
cdelgado@cityofberkeley.info
Cristi,
   That error will be seen when you are using an older version of eSearch in WAB 2.1 or even earlier. If you replace the eSearch folder with the most current release of eSearch 2.1.1 then that error will go away and as the configuration for the widget resides in a different folder you will not loose your configuration you have done previously.
Andrew,
   It was a null value in the numeric filed issue and I will have that fixed in the 2.1.2 release.
AndrewNiederhauser1
New Contributor III
Robert,
Thank you for looking into the issue and all your hard work on these incredible widgets.
Thanks again,
Andrew
JamesMarok1
New Contributor III
I don't know how to get that into single text box to search by, which is where I am stuck, I can replicate it esearch by creating multiple search boxes but I would like to use this default search box in the theme as well.
James,
  the 2.1.2 release will be able to search in the same way your app does.
BlakeTerhune
MVP Regular Contributor
Is there a way to only display one or two fields in the search results but have all the fields display in the popup? I'm using this with the custom popup panel widget that displays many fields; too many to have all turned on in the enhanced search widget's search results. If I only add one field to the Included Fields list, the popup that shows is missing all of the other field values. The stock search widget only lists one field in the results but displays the whole popup when you click a result.
Blake,
   You can find in the that there is a "popup only" option on the included fields grid of the add/update layer search setting page.
Version history
Last update:
‎11-22-2022 07:31 AM
Updated by:
