If the geometry is other than a point and you do not have a zoom scale specified then the result geometry will be used and zoomed to (1.5 meaning the result geometry envelope plus 50%). To change this to zoom out further then change this line:
this.map.setExtent(gExt.expand(1.5), true) (2.0 would be twice the size of the geometry).
You have the ability to change the buffers color in the Widgets settings page. As far as advice on creating your own widget You are doing what my advice would be (look at existing widgets to borrow code from).
Thanks for your quick response! I was wondering when you change field format in eSearch widget (please see screenshot below) Where should these changes be reflected, in a popup or in the results tab and a corresponding attribute table? In my case whatever I do to change field order and digit precision in the edit field window of the eSearch widget, does not get reflected anywhere. So my trails have 10 digit precision ...
Any advice? I am new to the WAB and really appreciate any advice you could provide.. Thank you!
Outstanding widget! I just downloaded the widget and it works nicely. I do however need some advice on an issue that we have come across and I’m hoping thatesearchwidget can be the solution. Our Department has a Cadastral/Parcel layer with multiple Ownername fields (see below attachment) and I would like for the widget to search all ownername fields (Ownername1 – Ownername 20) to return all names that meet the search criteria and a count. In essence if I searched for the name “Troy” if there are 500 names that meet that criteria, I would like to see that 500 count in the results followed by all 500 names that contains “Troy.” Please advise.
The eSearch is not setup to be able to search multiple field for one entered value. The queryTask which the eSearch uses is not really the best for that. The FindTask on the other hand is specifically designed for just such as operation. The WAB OTB search widget is best suited for your desired workflow. The Search widget allows for multiple fields (searchFields) to be specified on a layer.
I have one search item set up to search across three fields. What I did was in the main configuration window I created a search based on my DeedHolder1 field and saved that. Then, I went into apps\#\configs\eSearch\config_EnhancedSearch.json and modified the "sqltext" value of that search item to this:
"sqltext": "Upper(DeedHolder1) LIKE Upper('%[value]%') OR Upper(DeedHolder2) LIKE Upper('%[value]%') OR Upper(DeedHolder3) LIKE Upper('%[value]%')",
I don't know if rscheitlin advises against this or not but this has worked for me for 2+ years.
Adam thanks for sharing this. It does work as you know, but the widget settings UI is not designed to support this. Other than the settings UI not being designed to support this, there is no issue at all with your setup.
I am having an weird issued on one of my search expressions using the eSearch v2.4 and WAB 2.4. . I am trying to search by Parcel ID that is a 9 digit number inside a text field for example 010008909. The problem I am having it is not searching numbers after the 6 digit spot. So If I search 0100 or 1000 or 000 I get results but if I search 8909 or 10008 I get no results. I am using the exact same service with a WAB 1.1 and eSearch v1.2.0.5 with no issues. Looking at the code configuration for this search also looks the same. I also have a Party Name search set within the same layer and this appears to be functioning correctly.
Robert Attached is a screen shot of the console. I used firefox and chrome and got similar results. I did one search using the party name which is a second search expression in the same layer, one with a working parcel id search and one with the "no results" on a parcel ID search using 8909.
When I added your url and set the search expression to PID contains, ask for values. I had no problem returning results for 8909. So there must be something in your config from 1.2 that is causing a problem in 2.4.
I didn't import or copy any configs settings from 1.2 into 2.4, I completely re-set it up just using the same parameters in WAB thru the widget config window. I even removed the expression and re-added it. Maybe i can try removing the layer completely and re-adding it.
The search widget does everything I need except provide a "count." The Inland Revenue Department needs a workflow that has an owner name entered and sum of that search in the results. Is there a FIndtask widget that can be used?
Does this work with the 10.5.1 built in appbuilder. Have added as a custom widget, shared with everyone. however when clicking the widget get a spinning / waiting and nothing appears to happen.
I removed the layer completely and re-added it and them seemed do the trick. I however did notice another little bug. My Auto zoom to search results is not working. When I do a search the map stays at the current extent, even when there is only one result. I deleted the widget completely in the client apps folder and put a fresh copy of it back in there and reconfigured the app and it still doesn't do it.
In regards to the auto Zoom I finally saw in the individual search layers configuration in the Search widget that there is an auto zoom in the Global Settings Override. I guess I was confused or didn't realize that I needed to have this checked also even if I have it checked in the initial window of the Search widget.
Secondly, I think I figured out the root of the problem with it not searching past so many digits on a numbered search. When I initially removed the layer completely and put it back in there I tested it only by putting in the search expression and not configuring anything else and it worked fine. I have now finished setting up the layer and it stopped working. I have found that when I put in an Item sorting criteria (which is by one field) it doesn't allow the results. When I remove it the results are found again. I have tried to to sort by initial one (Party Name) and by PID and both fails my search results. I have the sorting set up on other layers without issue but the rest of the layers results are combination of letters and numbers unlike this one where it is all numbers. Also, this sorting was not an option on by earlier version of the search widget which might explain why I hadn't run into this problem before.
This is a great widget, thanks so much. I have a use case where I have over 100 fields and in many instances only 15-20 of those are populated. Can you advise me on how to return only the fields that have a value in the search results? It would be nice if users didn't have to scroll through the whole list. I imagine this is possible, but I am not sure how to code that. Do you have any ideas?
So Adam if I can ask, the concept would be if it detected field.length < 1. And additionally if the value was was a word such as 'null' or '0' or similar. (Or perhaps even other words e.g. NoData, None, etc) In terms of pseudocode. Now if it is simply hiding the same fields always, he added a box to uncheck everything, then check on specific fields. (I am so grateful he added that a while back). But your case it sounds like sometimes the field would have values, and sometimes not. So you only want to show it when they've got data. That does sound useful. I'd leverage it on our property layer.
Robert Scheitlin, GISP Philip Hughes I was able to get the widget to work in the "new" 10.5.1 Custom Widget deployment approach by changing the following lines in the code, all in the "setting" folder:
for any .js file in the /setting folder that references another script in the define() like 'widgets/eSearch/setting/AddFieldBtn', change the syntax to './AddFieldBtn' (dot-relative) -- basically replacing 'widgets/eSearch/setting' with '.' wherever it appears in a define()
in setting/IncludeBotton.js and setting/IncludeAllButton.js, change the last line in define() from 'dojo/i18n!./nls/strings' to './nls/strings'
I don't know enough JS or about how this was developed to know if these changes should go into the actual release of the app, I'll let Robert speak to that.
Yes, Kevin, that is correct. The idea would be to hide a field from the results if that field was empty, or had a null value. It would be very useful in limiting the results so users don't have to scroll through a long list of blank values. Really, I would like to see this in the pop-up window as well. I just thought I would reach out to see if it's something Robert has thought about adding to his custom widget at any time.
I apologize if this has been asked before but I can't seem to figure out how to search through only these comments.
I am trying to pass more than one search string via URL using a pipe according to the help. I am testing it out on your demo site using: esearch=1998|54962&slayer=3&exprnum=0 to have it find two parcels and it doesn't seem to work. Am I misunderstanding this functionality?
Ultimately what I want to do is take a list of parcel IDs and have it search for all of them at the same time using a URL parameter.
If you want it to search for both 1996 and 54962 then you have to switch your expression to use "in" and not equals or contains and use "esearch=1998,54962&slayer=3&exprnum=0"
Hey Sam Libby, this solution is close on my end, but doesn't completely work. The eSearch configuration page loads with your changes, but when I click on 'Add a Search Layer', it crashes because of SingleSearchEdit.html. I tried changing the data-dojo-types that reference other scripts to be dot-relative, but it's out of scope in this file. It's trying to look for /arcgis/jsapi/jsapi/dojo/IncludeButton.js. So I tried an absolute path, which fixed the problem for the LayerFieldChooser type, but IncludeButton and IncludeAllButton are still broken. Here's the error on Chrome:
Do you (or anyone else) know why changing the data-dojo-type path isn't working with types that use nls/strings in 10.5.1? I'm a JavaScript/WAB developer newbie, so I hope somebody knows the answer.
Edit: I'm also seeing this issue in Robert's Identify widget for setting/IdentifyLayerEdit.html when deployed in 10.5.1.
Hey Robert! Thank you so much for looking into 10.5.1 compatibility! Unfortunately, this build isn't working. When I added the widget to my app, the configuration page won't load, and this message appeared:
I dropped your widget straight into wwwroot (for now), so the path it's trying to use is correct. I see in your build that IncludeButton and IncludeAllButton still have 'dojo/i18n!./nls/strings' in the define. When I followed Sam's instructions to change this to './nls/strings', I was able to get past this error, but it just leads to the error I showed above.
catch(e){
if (newSub.getAttribute("slang").toLowerCase() != code_l.toLowerCase()) {
if (trLabelsHtml != "") {
var labelSname = "";
if(labelEle[i].querySelector("ul li:nth-child(1)").getAttribute("aria-hidden")){
labelSname = labelEle[i].querySelector("ul li:nth-child(1)").outerHTML;
labelEle[i].innerHTML = "";
labelEle[i].innerHTML = labelSname + trLabelsHtml;
catch(e){
/* V 2.0:3 = Store not translated reply id */
if(lingoRSXML.snapshotLength == 0){
if($scope.falseReplyID == "") {
$scope.falseReplyID = value;
/* Get translated Body of Replies/Comments */
var lingoRBXML = doc.evaluate(lingoRBExp, doc, null, XPathResult.UNORDERED_NODE_SNAPSHOT_TYPE, null);
for(var i=0;i 0) {
var attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('div.custom-attachments');
if (attachDiv) {
attachDiv = attachDiv.outerHTML;
else if(rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('#attachments').length > 0){
if ("TkbArticlePage" == "BlogArticlePage") {
attachDiv = rootElement.querySelector('div.lia-quilt-row-main .lia-message-body-content').querySelector('#attachments');
if (attachDiv) {
else{
attachDiv = "";
}else{
attachDiv = rootElement.querySelector('div.lia-quilt-row-main').querySelector('#attachments').outerHTML;
else {
attachDiv = "";
/* Feedback Div */
var feedbackDiv = "";
var feedbackDivs = rootElement.querySelector('div.lia-quilt-row-main').querySelectorAll('div.lia-panel-feedback-banner-safe');
if (feedbackDivs.length > 0) {
for (var k = 0; k < feedbackDivs.length; k++) {
feedbackDiv = feedbackDiv + feedbackDivs[k].outerHTML;
else {
var attachDiv = rootElement.querySelector('div.lia-message-body-content').querySelector('div.Attachments.preview-attachments');
if (attachDiv) {
} else {
attachDiv = "";
/* Everyone tags links */
if (document.querySelectorAll("div.TagList").length > 0){
var everyoneTagslink = document.querySelector('div.lia-quilt-row-main').querySelector(".MessageTagsTaplet .TagList");
if ((everyoneTagslink != null)||(everyoneTagslink != undefined)){
everyoneTagslink = everyoneTagslink.outerHTML;
else{
everyoneTagslink = "";
/* Feedback Div */
var feedbackDivs = rootElement.querySelector('div.lia-message-body-content').querySelectorAll('div.lia-panel-feedback-banner-safe');
for (var m = 0; m < feedbackDivs.length; m++) {
feedbackDiv = feedbackDiv + feedbackDivs[m].outerHTML;
} catch (e) {
if (body_L == "") {
/* V 2.0:7 Replacing translated video data with source video data */
var newBodyVideoData = newBody.querySelectorAll('div[class*="video-embed"]');
angular.forEach($scope.videoData[value], function (sourceVideoElement, index) {
if (index <= (newBodyVideoData.length - 1)) {
newBodyVideoData[index].outerHTML = sourceVideoElement.outerHTML
/* V 2.0:7 = Replacing translated image data with source data */
var newBodyImageData = newBody.querySelectorAll('[class*="lia-image"]');
angular.forEach($scope.imageData[value], function (sourceImgElement, index) {
if (index <= (newBodyImageData.length - 1)) {
newBodyImageData[index].outerHTML = sourceImgElement.outerHTML;
/* V 2.0:7 = Replacing translated pre tag data with source data */
var newBodyPreTagData = newBody.querySelectorAll('pre');
angular.forEach($scope.preTagData[value], function (sourcePreTagElement, index) {
if (index <= (newBodyPreTagData.length - 1)) {
newBodyPreTagData[index].outerHTML = sourcePreTagElement.outerHTML;
var copyBodySubject = false;
if (body_L == "") {
copyBodySubject = true;
body_L = newBody.innerHTML;
/* This code is written as part of video fix by iTalent */
/* try{
var iframeHTMLText = body_L;
var searchIframeText = "<IFRAME";
var foundiFrameTag;
if (iframeHTMLText.indexOf(searchIframeText) > -1) {
foundiFrameTag = decodeHTMLEntities(iframeHTMLText);
foundiFrameTag = foundiFrameTag.split('src="')[1];
body_L = foundiFrameTag;
catch(e){
/* This code is placed to remove the extra meta tag adding in the UI*/
try{
body_L = body_L.replace('<meta http-equiv="Content-Type" content="text/html; charset=UTF-8" />','');
catch(e){
/** We should not replace the source content if user profile language and selected target language matches with source language **/
if(showTrContent) {
var compiled = false;
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = null
if("TkbArticlePage"=="IdeaPage"){
// var customAttachDiv = '';
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv ;
$compile(rootElement.querySelectorAll('div.lia-message-body-content')[0])($scope);
compiled = true;
/* Attach atttach div */
// document.querySelector("div.translation-attachments-"+value).innerHTML = attachDiv;
rootElement.querySelectorAll('div.lia-message-body-content')[0].insertAdjacentHTML('afterend',attachDiv);
if(rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message').length > 1){
rootElement.querySelectorAll('div.lia-quilt-idea-message .lia-message-body .lia-attachments-message')[1].remove();
} else {
if("TkbArticlePage"=="TkbArticlePage"){
}else{
rootElement.querySelectorAll('div.lia-message-body-content')[0].innerHTML = body_L + feedbackDiv + attachDiv;
compiled = true;
/* Destroy and recreate OOyala player videos to restore the videos in target languages which is written by iTalent as part of iTrack LILICON-79 */ /* Destroy and recreate OOyala player videos */
try{
// $scope.videoData[value][0].querySelector("div").getAttribute("id");
for(var vidIndex=0; vidIndex<$scope.videoData[value].length; vidIndex++){
if( $scope.videoData[value][vidIndex].querySelector("div") != null){
var containerId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].containerId;
videoId = LITHIUM.OOYALA.players[$scope.videoData[value][vidIndex].querySelector("div").getAttribute("id")].videoId;
/** Get the Video object */
vid = OO.Player.create(containerId,videoId);
/** Destroy the video **/
vid.destroy();
/** recreate in the same position */
var vid = OO.Player.create(containerId,videoId);
catch(e){
try{
for(var vidIndex=0; vidIndex<($scope.videoData[value].length); vidIndex++){
if($scope.videoData[value][vidIndex].querySelector('video-js') != null){
var data_id = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-video-id');
var data_account = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-account');
var data_palyer = $scope.videoData[value][vidIndex].querySelector('video-js').getAttribute('data-player');
var div = document.createElement('div');
div.id = "brightcove";
div.class = "brightcove-player";
div.innerHTML =
'(view in my videos)'
var data = div.getElementsByClassName("video-js");
var script = document.createElement('script');
script.src = "https://players.brightcove.net/" + data_account + "/" + data_palyer + "_default/index.min.js";
for(var i=0;i< data.length;i++){
videodata.push(data[i]);
for(var i=0;i< videodata.length;i++){
document.getElementsByClassName('lia-vid-container')[i].innerHTML = videodata[i].outerHTML;
document.body.appendChild(script);
catch(e){
if(!compiled){
/* Re compile html */
if (code_l.toLowerCase() != newBody.getAttribute("slang").toLowerCase()) {
/* Adding Translation flag */
var tr_obj = $filter('filter')($scope.sourceLangList, function (obj_l) {
return obj_l.code.toLowerCase() === newBody.getAttribute("slang").toLowerCase()
if (tr_obj.length > 0) {
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.".replace(/lilicon-trans-text/g, tr_obj[0].title);
try {
if ($scope.wootMessages[$rootScope.profLang] != undefined) {
tr_text = $scope.wootMessages[$rootScope.profLang].replace(/lilicon-trans-text/g, tr_obj[0].title);
} catch (e) {
} else {
//tr_text = "This message was translated for your convenience!";
tr_text = "Esri may utilize third parties to translate your data and/or imagery to facilitate communication across different languages.";
try {
if (!document.getElementById("tr-msz-" + value)) {
var tr_para = document.createElement("P");
tr_para.setAttribute("id", "tr-msz-" + value);
tr_para.setAttribute("class", "tr-msz");
tr_para.style.textAlign = 'justify';
var tr_fTag = document.createElement("IMG");
tr_fTag.setAttribute("class", "tFlag");
tr_fTag.setAttribute("src", "/html/assets/langTrFlag.PNG");
tr_fTag.style.marginRight = "5px";
tr_fTag.style.height = "14px";
tr_para.appendChild(tr_fTag);
var tr_textNode = document.createTextNode(tr_text);
tr_para.appendChild(tr_textNode);
/* Woot message only for multi source */
if(rootElement.querySelector(".lia-quilt-forum-message")){
rootElement.querySelector(".lia-quilt-forum-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-message-view-blog-topic-message")) {
rootElement.querySelector(".lia-message-view-blog-topic-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-blog-reply-message")){
rootElement.querySelector(".lia-quilt-blog-reply-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-message")){
rootElement.querySelector(".lia-quilt-tkb-message").appendChild(tr_para);
} else if(rootElement.querySelector(".lia-quilt-tkb-reply-message")){
rootElement.querySelector(".lia-quilt-tkb-reply-message").insertBefore(tr_para,rootElement.querySelector(".lia-quilt-row.lia-quilt-row-footer"));
} else if(rootElement.querySelector(".lia-quilt-idea-message")){
rootElement.querySelector(".lia-quilt-idea-message").appendChild(tr_para);
} else if(rootElement.querySelector('.lia-quilt-occasion-message')){
rootElement.querySelector('.lia-quilt-occasion-message').appendChild(tr_para);
else {
if (rootElement.querySelectorAll('div.lia-quilt-row-footer').length > 0) {
rootElement.querySelectorAll('div.lia-quilt-row-footer')[0].appendChild(tr_para);
} else {
rootElement.querySelectorAll('div.lia-quilt-column-message-footer')[0].appendChild(tr_para);
} catch (e) {
} else {
/* Do not display button for same language */
// syncList.remove(value);
var index = $scope.syncList.indexOf(value);
if (index > -1) {
$scope.syncList.splice(index, 1);
/* V 1.1:2 = Reply Sync button for multi source translation */
} catch(e){
console.log(e);
if((rContent != undefined) && (rContent != "")) {
drawCanvas(decodeURIComponent(rContent));
/** Update variable with selected language code **/
$scope.previousSelCode = code_l;
* @function manageTranslation
* @description Managess the translation of given language for the thread
* @param {string} langCode - Language Code
* @param {string} tid - Thread ID
$scope.manageTranslation = function (langCode, tid) {
//debugger;
$scope.showTrText = false;
/* V 2.0:5 = actualStatus variable introduced to indicate detailed connector status on UI. This variable holds the actual translation percentage */
$scope.transPercent = "";
$scope.actualStatus = "";
if (tid != "") {
var bulkTranslation = lithiumPlugin.bulkTranslation(langCode, tid);
bulkTranslation.then(function (trContent) {
if(trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, langCode);
if(langCode != "en-US") {
$scope.showTrText = true;
if((trContent.status != "NA") && trContent.status != null) {
// $scope.transPercent = String(trContent.status);
$scope.actualStatus = String(trContent.status);
} else {
// $rootScope.errorMsg = "Translation is in progress. Please check again a few minutes."
$rootScope.errorMsg = "Translation is in progress. Please retry in a few minutes."
$scope.workbench = trContent.wb;
/* V 2.0:4 = Trigger uncalled or delayed callbacks (documnet uploaded/translation completed from lithium).*/
if(trContent.callback == 'true') {
var trCompletCallback = lithiumPlugin.trCompletCallback(langCode, trContent.docID);
trCompletCallback.then(function (callback){
// $rootScope.errorMsg = "Downloading Translated content in " + langCode + " now. Please check again in a few minutes."
$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if (trContent.callback == 'upload') {
var trCompletUpload = lithiumPlugin.trCompletUpload(langCode, trContent.docID);
trCompletUpload.then(function (callback) {
//$rootScope.errorMsg = "Uploading content to translate. Please check again in a few minutes."
} else if ("many" == "one") {
$scope.updateOOS();
} else if("SmartConx" == "SmartConx"){
if ("many" == "many"){
$scope.updateOOS();
}else if ((trContent.status != null) && trContent.status.includes("100")) {
/* If everything fine then only check Out of Sync status */
$scope.updateOOS();
} else {
/* If translation perccent is less than 100 then show the percentage on UI */
$scope.transPercent = $scope.actualStatus;
* @function selectThisLang
* @description Called on select dropdown.
* @param {string} lang - Language code
$scope.selectThisLang = function (lang, anonymousFlag) {
/* 1.4:3 Update Analytics on language selection */
try {
lingoThreadLangSelected(lang, '910880');
} catch (e) {
/** Display Translated content **/
var getTranslation = lithiumPlugin.getTranslation(lang, "910880");
getTranslation.then(function (trContent) {
if (trContent.body != "") {
$scope.showPreview(trContent.body, $scope.mszList, lang);
} else {
//$rootScope.errorMsg = "Translation is in progress. Please check again in a few minutes."
var decodeEntities = (function() {
// this prevents any overhead from creating the object each time
var element = document.createElement('div');
function decodeHTMLEntities (str) {
if(str && typeof str === 'string') {
// strip script/html tags
str = str.replace(/
