Accessing an nls string from an event
1299
04-06-2017 02:41 PM
KenBuja
I've created a Toggle Button in the postcreate function
this.signin = new ToggleButton({
  showlabel: true,
  checked: false,
  label: this.nls.signin,
  onChange: this._onBtnSignInChanged
}, this.btnSignIn);‍‍‍‍‍‍
In the onChange event, I'd like to change the label to another string.
_onBtnSignInChanged: function (val) {
  if (val) {
    this.set('label', nls.signin);
  } else {
    this.set('label', nls.signout);
However, this gives the error "Uncaught TypeError: Cannot read property 'signout' of undefined". What's the right way of accessing the nls to get that string? I suspect I have to use lang.hitch somewhere, but everywhere I've tried gives me another undefined error.
RobertScheitlin__GISP
Ken,
   If this.nls.signin (like Sapna recommends) in your function does not do the trick, then your lang.hitch would be here:
  showlabel: true,
  checked: false,
  onChange: lang.hitch(this, this._onBtnSignInChanged)
sapnas
It looks like you  are not referencing "this" in onChange event. shouldnt that be this.nls.signin and this.nls.signout. assuming that signout is defined in string.js?
Ken,
  showlabel: true,
  checked: false,
KenBuja
In my original code, I had this.nls.signin but had stripped out the "this" at one point as I tried various options. This is what finally worked (although I could have sworn I tried this yesterday)
 showlabel: true,
 checked: false,
}, this.btnSignIn);
  console.log(this.nls.signout);
  if (val) {
    this.signin.set('label', this.nls.signin);
  } else {
    this.signin.set('label', this.nls.signout);
