Custom Theme - Style.css not applying
4239
03-23-2015 01:23 PM
SamDrummond2
Hello All,
I'm in the process of developing a custom theme for the web appbuilder version 1.1.  I am going to customise the FoldablePanel from the Foldable Theme. As Such I have:
1. Copied the entire FoldableTheme\panels\FoldablePanel folder to my [CustomTheme]\panels\FoldablePanel directory
2. Added the following to the [CustomTheme]\manifest.json file:
    "panels": [{
      "name": "FoldablePanel",
      "description": "This is foldable panel"
3. Added the following to the [CustomTheme]\layouts\default\config.json file:
"widgetPool": {
    "panel": {
    "uri": "themes/[CustomTheme]/panels/FoldablePanel/Panel",
    "positionRelativeTo": "map",
    "position": {
      "top": 50,
      "right": 5,
      "bottom": 5
I can open http://[ServerName]/webappbuilder/?id=stemapp and I can see the foldable panels working in the Foldable theme. However, when I switch to my custom themes and open a widget it loads in the foldable panel but the styles from [CustomTheme]\panels\FoldablePanel\style.css.
Any one have any ideas as to what is happening?
Regards
Sam
NEvatt
Hi Sam,
I am not using 1.1 just yet, but looking at my config file for an older version that uses a custom theme my the set up is a little bit different.
Within the widgetOnScreen section, my config is set up like this:
"panel": {
            "uri": "themes/DemoTheme/panels/SimpleBorderPanel/Panel",
        "widgets": [{
            "uri": "themes/DemoTheme/widgets/HeaderController/Widget",
            "positionRelativeTo": "browser",
            "position": {
                "left": 46,
                "top": 20,
                "right": 0,
                "height": 64
            "id": "themes/DemoTheme/widgets/HeaderController/Widget_5",
            "name": "HeaderController",
            "isThemeWidget": true,
            "label": "Header Controller"
and then the panel is set up on the widgetPool section:
"panel": {
            "uri": "themes/DemoTheme/panels/FoldablePanel/Panel",
            "position": {
                "top": 5,
                "right": 5,
                "bottom": 5
This code may no longer be relevant, but is worth a try.
-Nat
StanMcShinsky
I have not set up my own custom theme yet, but it looks like Nat may be referencing the config in the root of the application and Sam is referencing \themes\FoldableTheme\layouts\default\config.json
-Stan
SamDrummond2
Hey Nat and Stan,
Nat thanks for replying but Stan is correct. I'm still working in a dev environment and I'm simply opening the stemapp using http://[servername]/webappbuilder/?id=stemapp​ and manually changing the theme using the WAB.
S
