dijit confirm dialog appears behind other elements
1236
02-22-2017 10:02 AM
Alexwang
Occasional Contributor II
Hi all, I have a dijit confirm dialog so it pops up when a user is going to delete something. The issue was that the confirm dialog always appeared behind a tooltip dialog. Please see screenshot below. Is there a way to let the confirm dialog always appears on the top. I tried z-index but the confirm dialog doesn't seem to have a z-index attribute. Any suggestions?
RobertScheitlin__GISP
Alex,
   If you say that it does not have a z-index then you have to give it one.
Alexwang
Thank you Robert. It gave me a creating widget error when i added the z-index to the Confirm Dialog constructor.
Alex,
   No you do not place a css property like z-index in the constructor you place it in the style.
