eDraw widget
74423
250
02-24-2015 01:17 AM
JeremieCornet1
Occasional Contributor II
Ehanced draw widget for WebApp Builder for Arcgis
UPDATE 2018/05/09 (new Release v2.8.1) :
  • refactoring
  • use esri/geometry/projection (available since esri js api 3.24) instead of proj4js (external libs)
  • systematic use of geometry engine (no more mercator utils, geometry server...)
  • for polyline, the user can now add an arrow (available since esri js api 3.23)
  • live measure while drawing
  • WARNING : this release needs Esri API >= 3.24
Release 2.8.1 on Github
(Direct zip link : https://github.com/magis-nc/esri-webappbuilder-widget-eDraw/releases/download/v2.8.1/eDraw.zip )
Demo : https://apps.magis.nc/demo/eDraw/
Github  :
Wigdet's Features (improvments of standard Draw widget) :
  • add name and description fields on drawings
  • enable infowindow on drawings (selection)
  • on text drawing, no insert if no name.
  • on modification : enable geometry update (with snapping if wanted : CTRL) and preview symbology changes on the fly
  • list
    • add list of all drawings
    • actions on each drawing : modify / delete / [up / down] / zoom
    • all drawings : zoom, copy, delete, export
    • on drawing infowindow -> select drawing in list
    • on zoom on a drawing -> select drawing on map (and show infoWindow)
    • re-order graphics with drag&drop
  • import/export : allow users to export or import drawings (json format)
    • import can be done with file drag&drop in import popup
  • localStorage
    • dynamic saving on each drawing add/delete/update
    • on widget load : load drawings saved in local Storage
  • draws plus (initially from Larry Stout https://geonet.esri.com/people/Larry_Stout)
    • preview under mouse when adding text or point
    • for text, add font choice, font angle, bold, italic, placement and underline options.
    • add arrow menu for polyline
  • checkbox to hide drawing's layer (and therefore widget UI)
  • add of Nautical unit
  • measure's for points/polylines/polygons with automatic update on element's update (or delete). Measure's can be indidualy disabled/enabled on any graphic.
  • "On the fly" measure when drawing
  • defaults symbols can be specified in config's file
  • use of builtin projection engine (available since esri js api 3.24) instead of proj4js library
This message was updated by Jeremie Cornet (New Release)
AdamGebhart
Occasional Contributor III
Thank you.  Just checking on that as I think our end-users will really like this widget.
RavitejaViswanadha1
New Contributor III
Hi Jeremie Cornet,
Thanks for the excellent Widget.
This is very useful and while using we have encountered a  situation in using the "Show Measurement" feature.
Here is the steps to reproduce that issue.
  • Click on Draw widget and turn on the Show Measurement checkbox
  • Select the drawing mode as EXTENT
  • Zoom in an area and draw a rectangle on the map
  • Click on Update this drawing icon from the Draw window
  • Zoom out and change the size of the mark up drawing
  • Observe that the Area value of the drawing does update
Can you please lnto this and let us know the fix !
JeremieCornet1
The measure part of the widget isn't modified (In fact, there is a little modification which add the measure's text in eDraw layer instead og map graphics layer).
So this is not an issue.
I may refactor the measure part in the future (and make it dynamic) but it's not my priority for now.
MariaNieves
New Contributor III
Hi Jeremie,
I am using this widget and wanted to let you know that iPad (Safari) users can't change the colors on any drawings.
Maria
JeremieCornet1
I cannot reproduce the error (i havn't iPad).
Can you change the colors with the standard draw widget ?
JeremieCornet1
New release (1.2.2). Please see first post.
Zachary Schmitt​ You can now export checked drawings.
GeorgeKatsambas
I cannot get the widget to load? I add it to my clientstemap folder but when in WAB and I try to add widget I get nothing. I tried IE 10 and Chrome, and version 1.21 as well as 1.22. I get a blank draw icon and a blank message box with  just the option to click ok.edraw error.gif
MassimoBisogno
New Contributor II
Hi Jeremi i got this error when add edraw to my WAB 1.2
JeremieCornet1
George KatsambasMassimo Bisogno
I can't reproduce the bug.
Could you tell me what says the javascript console ?
MassimoBisogno
New Contributor II
Hello Jeremi,
I use WAB 1.2, and the error occurs only when you add the widget to the webapp for the first time, when you have to configure. I did OK and I open again the configuration form and now seems to be working properly. I try again with a new webapp and I'll let you know. Thank you.
