Enhanced Search Widget
2472
22
09-11-2018 08:47 AM
RickEhlin__Jr
I can't seem to get this widget to function??  I've only set up one layer to search for, but it never seems to load?
RobertScheitlin__GISP
Rick,
  OK. I do not use Portal personally so I forgot someone else mentioned that Portal was missing that file (and my widget counts on it being there). So I have attache that file and you need to add it to the path mentioned in the error you posted.
RickEhlin__Jr
attach it to https://<myserver>./portal/apps/webappviewer/jimu.js/CSVUtils.js?wab_dv=2.6 ??
Will I have to re-download the file??
??? I provided the missing file in my last reply as an attachment.
RickEhlin__Jr
I don't see an attachment?  Sorry, I'm relatively new to GeoNet so I may be missing it?
Rick,
  You will not see the attachment if you just look from inside your GeoNet inbox. You have to actually open the thread by clicking on the title then it will show you the attachment.
RickEhlin__Jr
Thanks for your patience, I found the attachment.  I see the /portal/apps/webappviewer/ pathway when I open my WebApp, but I don't see the same pathway on my server?  I'm not sure where to place it.  Thanks for your time with this, it's greatly appreciated.
Rick,
  So you do not see a \portal\apps\webappviewer\jimu.js folder?
RickEhlin__Jr
I do not see that pathway on my server.  I have portal/
and the following folders
App_GlobalResources
css
js
WebAdaptor
WebAdaptorHelp
and following files
Global.asax
Web.config
WebAdaptor.config
I am assuming that since the error calls out my server that I should be looking in the wwroot folder location.
Rick,
   No that is not correct the Portal folder will not be under the wwwroot folder. More like C:/Program Files/ArcGIS/...
RickEhlin__Jr
Robert...thank you so much.  I seem to have gotten it to work.  I'm learning so much and I really appreciate your help and guidance through this.  You are a wizard!!!
