eSearch Searching Query
1808
17
01-05-2017 04:53 PM
RodWoodfordOld
Hi Robert,
I have a particular app that is using the eSearch widget and have had a request to configure on startup that the BY VALUE and BY SHAPE search functions start with different Map Service URLs. Basically operators will conduct a textual search using the BY VALUE option to gather results for URL1, with the map zooming in and then by clicking on the highlighted zoomed to property gather results from the second URL. Is this possible to configure?
example
BY VALUE configured to search on URL expression 1
BY SHAPE configured to search on URL expression 2
cheers
RobertScheitlin__GISP
Rod,
  OK do this then. Same thing at the very end of the _initLayerSelect function:
setTimeout(lang.hitch(this, function(){
  this.selectLayerGraphical.set('value', 2);
}), 500);
RodWoodfordOld
Hi Robert,
Yes that appears to have resolved the issue. I will do a couple of tests next week and mark answered if OK.
Cheers
Rod
RodWoodfordOld
Hi Robert,
After testing I have found on the very first time the operator does a search it doesn't work. But if they select the CLEAR FIELD button in the BY VALUE display it does work every time after that as it changes the BY SHAPE dropdown to the correct search option. If this can be resolved then that should be it.
cheers
Rod,
  Please zip and attach your Widget.js for me to look at.
RodWoodfordOld
Hi Robert,
File attached.
cheers
Rod,
  Are you sure you sent me the updated Widget.js? If so then I do not see the last change (setTimeout) that you were suppose to add to the _initLayerSelect function.
RodWoodfordOld
Hi Robert,
Sorry for that. I made the change via remote login and it didn't save for some reason. Now I'm back in the office I have added the (setTimeout) to the widget.js file and the app works nicely. Thank you for the help.
Quick one, will all your widgets work with WABD 2.3?
cheers
Yes.
  Don't forget to mark this as answered.
