eSearch widget not displaying web map Popup
701
07-31-2020 06:12 AM
MartinOwens1
Occasional Contributor II
Does the eSearch widget not work work with Arcade expressions even though I've configured it to display the web map popup? I have a simple map for testing with only a basemap and 1 operational layer. I have configured the operational layer to display a popup using multiple arcade expressions in the web map. I configured the eSearch to use the same search layer that is in the web map and display the web map popup. When I click using the graphic select or select a result from a query the popup says No Information Available. When I disable the graphical search and click a feature it displays fine. What am I missing?
RobertScheitlin__GISP
Martin,
   I have not tested this, but I am not surprised that they do not work. Maybe this will be supported in the future.
Martin,
MartinOwens1
Thanks Robert.
