Hello
I would like to kwon how to get all map service records when using the chart widget.
I have a feature service with 62,000 points. I created a web application using the Webapp Builder developer edition. I want to show in a chart information about the points (now 62,000 in future maybe more). However, the widget is limited to the map service maxRecordCount, which is set to 1000.
I know I can change that value, but I do not want to because at some point the problem will be the same. I would like to have in the chart the exact amount of records in the layer… I would like it to be dynamic, meaning that the widget get the total of points. I have to point out that the chart is linked to the points on the map….
Is it possible?
I have arcgis server 10.3
Thanks for the help!
