How to get contents of a folder?
177
02-11-2019 04:19 PM
StahlyEngineering
Hello all,
I am trying to pass the contents of a folder (a set of documents) to an array within a widget. In the little research I've done it seem that this must be done through a server-side script (the target folder sits in the same place as the WAB server). However I can't figure out how to execute any such script from a widget.
Does the WAB support this capability since it's built on node.js? If so would an esriRequest be the right tool for the client-server communication?
links to tutorials would be much appreciated,
Thanks!
