Hi Robert
The URLS are correct. The widget does not Identify invisible featureserver layers. I tested today.. I could only get identify results by turning on those layers in my LayerList widget.
While waiting for your reply, I debugged and commented out this section and now it is working .... Is this the right solution?
IdentifyFeatures:Function(geom){
if (layer.type && layer.type === 'Feature Layer') {
if (!layer.url || layer.url === '' || !layer.hasOwnProperty('url')) {
return false;
if (this.config.layers.onlythese === true) {
if (this.isService2beIdentified(layer)) {
/* //BJ 5/5/2020, comment out this because I want to identify invisible layers for featureServer on AGOL
if (this.identifylayeroption === 'visible' || this.identifylayeroption === 'top') {
if (!layer.visible || !layer.isVisibleAtScale(this.map.getScale())) {
return false;
