For anyone trying to do this on Portal that came with 10.8.1
open the file: [Portal Instllation Folder]\apps\webappviewer\jimu.js
Look for a function
y.createWebMap = function(a, c, b, g) {
a = U.getStandardPortalUrl(a);
a = U.getBaseItemUrl(a);
C.arcgisUrl = a;
return C.createMap(c, b, g)
You may need to prettify the file
Replace with:
C.arcgisUrl = a;
def=C.createMap(c, b, g)
def.then(function (response){
var map = response.map;
var handle = dojo.query(".title", map.infoWindow.domNode)[0];
var dnd = new dojo.dnd.Moveable(map.infoWindow.domNode, {
handle: handle
return def;
//return C.createMap(c, b, g)
For CSS changes, I wanted to do in the FoldableTheme (You may change for theme you are working on).
Open file [Portal Instllation Folder]\apps\webappviewer\themes\FoldableTheme\common.css
Add this at the bottom
@import url("panels/FoldablePanel/style.css");
@import url("panels/DockablePanel/style.css");
.jimu-simple-panel {
-moz-border-radius: 4px;
-webkit-border-radius: 4px;
border-radius: 4px;
.jimu-link {
opacity: 0.8;
.esriPopupWrapper .title{
cursor: move;
