Move the popup window in WAB?
3692
12
11-27-2019 07:50 AM
CarolinaAguilar_Aravena
New Contributor II
I need a code that allows moving the pop-up window, since when viewing the map this window covers the layers of the map. I need this to better the user experience assistance. I use the code of How To: Enable drag function on an infoWindow pop-up in Web AppBuilder for ArcGIS  but generate this error.
ЭрикНазаров
New Contributor II
Can you please send the file "utils.js "?
imranrajjad_cc
New Contributor II
For anyone trying to do this on Portal that came with 10.8.1
open the file: [Portal Instllation Folder]\apps\webappviewer\jimu.js
Look for a function
y.createWebMap = function(a, c, b, g) {
a = U.getStandardPortalUrl(a);
a = U.getBaseItemUrl(a);
C.arcgisUrl = a;
return C.createMap(c, b, g)
You may need to prettify the file
Replace with:
C.arcgisUrl = a;
def=C.createMap(c, b, g)
def.then(function (response){
var map = response.map;
var handle = dojo.query(".title", map.infoWindow.domNode)[0];
var dnd = new dojo.dnd.Moveable(map.infoWindow.domNode, {
handle: handle
return def;
//return C.createMap(c, b, g)
For CSS changes, I wanted to do in the FoldableTheme (You may change for theme you are working on).
Open file [Portal Instllation Folder]\apps\webappviewer\themes\FoldableTheme\common.css
Add this at the bottom
@import url("panels/FoldablePanel/style.css");
@import url("panels/DockablePanel/style.css");
.jimu-simple-panel {
-moz-border-radius: 4px;
-webkit-border-radius: 4px;
border-radius: 4px;
.jimu-link {
opacity: 0.8;
.esriPopupWrapper .title{
cursor: move;
Tags (3)
HelenWhiteley_tfl
New Contributor II
I used the advice from https://support.esri.com/en-us/knowledge-base/000015175 to successfully make pop ups moveable. Unfortunately, before I could document my process, ESRI have removed the page! (404 error) Does anyone have a copy of what was in the page, or know how to successfully contact ESRI to request the page is reinstated?
Thanks
