Popup Widget - Auto Zoom to
679
11-06-2017 12:16 AM
RodWoodfordOld
Occasional Contributor III
Hi Robert,
Hope things are going well. Not sure if anyone has asked for this, but is it possible to configure the widget to auto zoom to when the map view is clicked. If not, can the ZOOM TO SELECTED button be placed at the top of the display so users can see it without the need for scrolling down the panel. Users just don't see it if there are many returned attributes. Any advice would be useful.
cheers
Tags (1)
RobertScheitlin__GISP
Rod,
   I don't think I want to do this permanently so here is the change you can make for your end. Replace the Widget.html content with this:
<div style="width: 100%;height:100%;">
  <div data-dojo-attach-point="header" class="popupheader">
    <div data-dojo-attach-point="instructions" style="width:100%;">${nls.selectfeatures}</div>
    <div data-dojo-attach-point="pager" style="display:none;">
      <div data-dojo-attach-point="featureCount" style="float:left;cursor:default;"></div>
      <a class="clear" href="#" data-dojo-attach-point="btnClear" title="${nls.cleartip}">${nls.clear}</a>
      <div class="titleButton next" title="${nls.next}" data-dojo-attach-point="next"></div>
      <div class="titleButton prev hidden" title="${nls.previous}" data-dojo-attach-point="previous" ></div>
    </div>
  </div>
  <div class="esriPopup esriViewPopup" style="width: 100%;">
    <div class="actionsPane" data-dojo-attach-point="actionsPaneDiv" style="padding-bottom: 8px;">
      <div class="actionList" data-dojo-attach-point="actionsListDiv">
      </div>
    </div>
  </div>
  <div data-dojo-attach-point="popupContent" data-dojo-type="dijit/layout/ContentPane"
    data-dojo-props="region:'center', style:'margin-top: 22px;'"></div>
</div>
Rod,
    </div>
  </div>
      </div>
    </div>
  </div>
</div>
RodWoodfordOld
Hi Robert,
Thanks for the prompt reply. That works nicely. Having the zoom to at the top just makes it that little bit easier for our web clients to use. I will add this to future upgrades.
cheers
Rod,
  In version 2.6 (now released) this is now a configuration option.
