Roberts Custom WAB Widgets
283145
475
12-31-2014 11:28 AM
RobertScheitlin__GISP
KyleCrawford2
New Contributor III
Hi Robert,
I am attempting to leverage your Google Street View widget in an application but when the Street View window opens it works for maybe 10 seconds and then I get the following error:
Any suggestions would be great!
KyleCrawford2
New Contributor III
To further comment on my first response this is the error I receive in the browser console:
I generated a Street View API key and placed it in the config.json file at "googleapikey":. I then set referrers for the API key but still receive the same error.
Kyle,
  Did you set the referrer to https: //webgis,altamonte.org? The less specific you are the better.
KyleCrawford2
New Contributor III
Robert,
The widget window just sits and loads when I make the referrer site less specific.
I saw that you responded to another user to just remove the Google API Key altogether.
Result in Chrome:
But, if I use this application in Internet Explorer I have no issues when removing the Google API Key. I have had issues before working with applications in Chrome. Do you know if this is a possible solution?
Kyle,
  Did you just set the api key to an empty string or did you delete the parameter all together?
KyleCrawford2
New Contributor III
Robert,
I set it to an empty string.    widgets\StreetView\config.json
Kyle,
  Can you test my Live Preview Site and see what happens?
KyleCrawford2
New Contributor III
Robert,
     The widget works fine for me in your Live Preview Site.
Kyle, so that tells you it is a configuration issue. I am not sure what to tell you now though.
KyleCrawford2
New Contributor III
Robert,
Thanks for your help! Without making any changes it just started working in Chrome so I'm just going to go with that.
