Hi Guys
Could someone please assist me, I used WAB v2.1 - 2.4 and my widgets was working fine. When the map started, the code inside the widget run. This was as simple as adding to the config file: "openAtStart": true
For some reason in v2.7 this is not the case and it seems the config files has changed.
Could someone please guide me on which config and what do I need to change in this version so that my widget will run when the map loads?
Thanks in advance.
Brett
