John,
To get the text in the button and remove the icon you would have to do a little re-write of the OnScreenWidgetIcon.js in the jimu folder:
define(['dojo/_base/declare',
'dojo/_base/lang',
'dojo/_base/array',
'dojo/_base/html',
'dojo/on',
'dijit/_WidgetBase',
'./utils',
'dojo/dom-style'
function(declare, lang, array, html, on, _WidgetBase, utils, domStyle) {
return declare(_WidgetBase, {
'class': 'jimu-widget-onscreen-icon',
postCreate: function(){
this.inherited(arguments);
this.iconNode = html.create('img', {
src: this.widgetConfig.icon
}, this.domNode);
domStyle.set(this.iconNode,"display", "none");
this.labelNode = html.create('div',{
style: 'color: white; padding: 11px;'
},this.domNode);
this.labelNode.innerHTML = this.widgetConfig.label;
html.setAttr(this.domNode, 'title', this.widgetConfig.label);
html.setAttr(this.domNode, 'data-widget-name', this.widgetConfig.name);
this.own(on(this.domNode, 'click', lang.hitch(this, function(){
this.onClick();
domStyle.set(this.domNode, 'width', 'auto');
this.position = lang.clone(this.widgetConfig.position);
if (this.widgetConfig.position.relativeTo === 'map') {
this.own(on(this.map, 'resize', lang.hitch(this, function() {
var _pos = lang.clone(this.position);
delete _pos.width;
delete _pos.height;
if (this.panel) {
this.panel.setPosition(_pos);
this.state = 'closed';
startup: function(){
onClick: function(){
if(this.state === 'closed'){
this.switchToOpen();
}else{
this.switchToClose();
moveTo: function(position){
var style = {
left: 'auto',
right: 'auto',
bottom: 'auto',
top: 'auto',
width: 'auto',
height: 'auto'
style = lang.mixin(style, utils.getPositionStyle(position));
delete style.width;
delete style.height;
html.setStyle(this.domNode, style);
this.position = lang.clone(position);
if (this.widgetConfig && this.widgetConfig.panel){
this.widgetConfig.panel.position = lang.clone(position);
this.widgetConfig.position = lang.clone(position);
if(this.panel){
this.panel.setPosition(lang.clone(position));
if(this.widget){
this.widget.setPosition(this.getOffPanelWidgetPosition(this.widget));
destroy: function(){
if(this.panel){
this.panelManager.destroyPanel(this.panel);
}else if(this.widget){
this.widgetManager.destroyWidget(this.widget);
switchToOpen: function(){
this.state = 'opened';
this.panelManager.closeAllPanelsInGroup(this.widgetConfig.gid);
array.forEach(this.widgetManager.getOnScreenOffPanelWidgets(), function(widget){
if(widget.closeable){
this.widgetManager.closeWidget(widget);
}, this);
html.addClass(this.domNode, 'jimu-state-selected');
this._showLoading();
if(this.widgetConfig.inPanel === false){
this.widgetManager.loadWidget(this.widgetConfig)
.then(lang.hitch(this, function(widget){
this.widget = widget;
widget.setPosition(this.getOffPanelWidgetPosition(widget));
this.widgetManager.openWidget(widget);
this.own(on(widget, 'close', lang.hitch(this, function(){
this._hideLoading();
}else{
this.panelManager.showPanel(lang.clone(this.widgetConfig))
.then(lang.hitch(this, function(panel){
this.panel = panel;
this.own(on(panel, 'close', lang.hitch(this, function(){
switchToClose: function(){
html.removeClass(this.domNode, 'jimu-state-selected');
this.widgetManager.closeWidget(this.widget);
}else{
this.panelManager.closePanel(this.panel);
getOffPanelWidgetPosition: function(widget){
var position = {
relativeTo: widget.position.relativeTo
var pbox = html.getMarginBox(this.domNode);
var sbox = this.widgetManager.getWidgetMarginBox(widget);
var containerBox = html.getMarginBox(position.relativeTo === 'map'?
this.map.id: jimuConfig.layoutId);
var top = pbox.t + pbox.h + 1;
if(top + sbox.h > containerBox.h){
position.bottom = containerBox.h - pbox.t + 1;
}else{
position.top = top;
if (window.isRTL) {
if(pbox.l + pbox.w - sbox.w < 0){
position.right = 0;
}else{
position.right = pbox.l + pbox.w - sbox.w;
} else {
if(pbox.l + sbox.w > containerBox.w){
position.right = 0;
}else{
position.left = pbox.l;
return position;
_showLoading: function(){
domStyle.set(this.iconNode,"display", "");
html.setAttr(this.iconNode, 'src', require.toUrl('jimu') + '/images/loading_circle.gif');
_hideLoading: function(){
html.setAttr(this.iconNode, 'src', this.widgetConfig.icon);
