Join fails after indexing table
3256
6
05-25-2016 06:49 AM
BrianLomas
Occasional Contributor III
While in arcmap joining a table to a polygon layer I'm prompted to index the joining table. If I do index the table then the join fails but if I decline the join will work. I'm joining based on OID of the polygon layer. Anybody have any ideas what might cause this? I ask because once indexed the table will not join with this layer ever again.
AdrianWelsh
MVP Honored Contributor
Brian,
What version of ArcMap are you using? Have you tried creating a different instance of this feature class in order to see if the join will work then (a copy)? How is your data stored (shapefile, geodatabase, etc.)?
Also, I wonder if it has something to do with indexing the OID. Maybe you can make a new field and copy the OID values over and try joining with that new field instead.
NeilAyres
And, if I may add, using the OID of the feature as a join item is a bad idea.
It could change if you edit the feature.
If this is a once off, as Adrian has said, add a new item to your feature and calculate the OID across to it.
And, I hope that in the join table the join item is not called OID or OBJECT_ID or anything like that.
BrianLomas
The polygon fc is in a SQL enterprise geodatabase. I would rather not alter the fc layer with an additional field just for this small project. Also, after joining I'm not editing the fc. I use the join just to cross check data after running a series of geoprocessing tools. There are other methods to check it but I was just curious on what I'm doing wrong. I've never had this happen before.
BrianLomas
Now, I'm working with different data but same conditions... a SQL feature class trying to join to a shapefile. Copied the OID to a new field but named differently. And again have the same problem, once the fields are indexed zero records match. Before indexing every single one match.
NeilAyres
And your new field is a LONG INT, and the join item the same?
Could you give us a picture of the data or perhaps post a sample here.
Sounds very strange. Must be a reason.
BrianLomas
Yea, new field is a LONG INT... I'm not sure how to upload sample data.
