Why can't I pull my shared map up in collector?
1794
7
04-07-2017 07:00 AM
deleted-user-rqN42KX6-Rcs
New Contributor III
I have published my map but it still will not load in Collector. Any advice?
DerekLaw
Esri Esteemed Contributor
Hi Matthew,
Just to add onto Michael's post, here's a link to the help documentation:
Create and share a map for data collection—Collector for ArcGIS | ArcGIS
Hope this helps,
MichaelMiller2
Occasional Contributor III
Collector will only open web maps that have data from a feature service, i.e. editable.
DerekLaw
Hi Matthew,
Hope this helps,
New Contributor III
Hello Derek,
I've added a location tracker in my ArcGIS Online map and now believe it won't work without also using the Collector for ArcGIS app. Unfortunately, I have a Windows phone and it doesn't seem possible to use unless I have an iPhone, Android, or PC. Is there a work-around for the Collector for ArcGIS app on a Windows phone without using Survey123 or GeoForm?
DerekLaw
Hi Matthew,
I'm not clear on your issue. Collector for ArcGIS is available on Windows Phone.
EDIT: Collector for ArcGIS is available for Windows 10 tablets and PCs. You can get it here,
Collector for ArcGIS - Microsoft Store
Hope this helps,
New Contributor III
Hello again Derek,
According to the Collector for ArcGIS - Microsoft Store link, the following is what shows on my phone:
I can't find any link for the Windows Phone.
New Contributor III
To be more precise, I have a Microsoft Lumina 735 Windows Phone 8.1 Update 2.
DerekLaw
Hi Matthew,
Apologies for the late reply, I was on business travel last week.
I'm also sorry, but I made a mistake in my previous post. As you pointed out, Collector for ArcGIS is NOT available on Windows Phone at this time, it's only available on Windows 10 tablets and PCs. I am sorry for my mistake.
FYI, this blog post was also just published:
ArcGIS Apps for the Field on the Windows Platform | ArcGIS Blog
Regarding your original question,
I'm not exactly sure what you want to do, but have you tried to use Web AppBuilder for ArcGIS to create a web app for your web map data, then open it in a web browser on your Windows Phone? It supports editing workflows, but does not support being disconnected.
Hope this helps,
