Catchment Polygon Processing
2132
04-11-2012 03:21 AM
ahmet_hamdisargin
Dear all,
while we were working Archydro in two different computers, I have 2 following  problems:
as you know, layers are raster until catchment grid delination (CGD). from now on, it will convert raster to vector. but unfortunately, I had no vector data catchment polygon processing (CPP), drainage lines and adjoint catchment.
I use ArcGIS 10, 64 bit.
1-
After finishing (CGD), program does not produce (CPP) . and I can not proceed.
It creates feature class, but it does not contain any data.
2-
After finishing catchment grid delination(CGD), program does not produce catchment polygon precessing(CPP)
It gives error: "H RESULT E FAIL has been returned from a call to a COM componeent"
I need your kind help.
MarkBoucher
Occasional Contributor III
The problem you are having may be because of other issues, not just that function.
Check out the tips here.
http://forums.arcgis.com/threads/48100-ArcHydro-Problem-Solvers
