ArcGIS Online Questions
240
74.8M
14.7K
Open | Can you please allow users to enable sync for features hosted on ArcGIS online with 64bit Object ID? by MiralemZeljo1 Occasional Contributor 0 0 | 0 | 0 | |
Open | Currently, if you want to swap the user license type between two users, you need a third unallocated license to play ... by RTPL_AU Occasional Contributor II 2 0 | 2 | 0 | |
Open | Add a widget which would allow for the display of notifications within a specific Hub site (as opposed to the banner ... by NCCGIA New Contributor II 1 1 | 1 | 1 | |
Open | Regarding resources like Ontario GeoHub's Open Web Map Services > Eastern Ontario > AGOL page:There is an option in t... by Bud Notable Contributor 0 0 | 0 | 0 | |
Open | HelloThe new Map viewer is missing the ability to output a hosted view layer when doing a join.This function works in... by MattyMaps New Contributor III 0 1 | 0 | 1 | |
Open | When creating Hosted Views of feature services and enabling them for offline use in Field Maps, if you don't include ... by LindsayRaabe_FPCWA Occasional Contributor III 1 0 | 1 | 0 | |
Open | We are increasingly being asked to create apps to track work being done by contractors doing work for the municipalit... by MelanieWawryk Occasional Contributor III 3 3 | 3 | 3 | |
Open | An organizational setting of the CDN cache control update period would be welcome.It now defaults to 30 seconds for a... by TrebinMT New Contributor II 2 0 | 2 | 0 | |
Open | I would like to see credit allocations enabled by default for ArcGIS Organizations. I believe that is an important pr... by PeterKnoop MVP Regular Contributor 1 2 | 1 | 2 | |
Open | Add an order button and functionality to feature layer lists. Currently the only way to order a feature layer's list ... by Maranta New Contributor II 1 1 | 1 | 1 | |
Open | I really like the ability to group layers in the new map viewer, and save them as a group layer. It would be really g... by StephenKing3 New Contributor III 2 0 | 2 | 0 | |
Open | Need to have the ability to select multiple features in the ArcGIS Online map viewer. Also would be helpful if you co... by AdamMoszynski New Contributor III 0 0 | 0 | 0 | |
Open | Idea: allow publishing featureserver service from a file gdb. I know editing needs an RDBMS backend and SDE. However... by Kevin_MacLeod New Contributor III 0 0 | 0 | 0 | |
Open | This would be a best improvement to ArcGIS online that ever occurred.We are looking for ways to export a folder with ... by MiralemZeljo1 Occasional Contributor 7 4 | 7 | 4 | |
Open | I need to share my data with the Group consisting of my company's peers. They will edit my data. Also, I need to shar... by AlexZhuk Occasional Contributor III 1 2 | 1 | 2 |
Idea Submission Guidelines
User | Count |
10 | |
9 | |
7 | |
6 |
