ArcGIS Survey123 Blog
451
71.2M
277
Open | We would like to not only take a basemap, but also other layers offline when using the Web Map offline function for S... by HubertGimpl1 New Contributor II 0 0 | 0 | 0 | |
Open | It is often required to have a unique id that is not a gloablid structure in reports so they can be linked to the ser... by NicholasMoore Occasional Contributor 3 2 | 3 | 2 | |
Open | I'm a team manager (I have several team managers) and I have a layer where each person can view their own data (we ha... by João_CarlosPinto_Fernandes New Contributor III 0 0 | 0 | 0 | |
Open | Currently, when using a hi-precision bluetooth receiver (Trimble R1/R12i and Leica GG04 Basic Plus) on Android OS 13 ... by JoelCusick1 New Contributor III 0 1 | 0 | 1 | |
Open | Could a toggle be created to turn off the default Survey123 camera interface and enable the native device interface i... by HowardBeverly1 New Contributor II 2 0 | 2 | 0 | |
Open | Very similar to ENH-000119959 that was implemented at 3.13, I am looking to pull a choice list from a json return fro... by Greg_Mattis Occasional Contributor II 8 2 | 8 | 2 | |
Open | We have recently come across an issue trying to use the Survey123 Field App on Windows where the 'Location Inaccessib... by RobertAnderson3 MVP Regular Contributor 4 1 | 4 | 1 | |
Open | ArcGIS Survey123 (for Windows) and ArcGIS Survey123 Connect are used extensively at my government agency. I think th... by SamuelWeissman New Contributor II 29 0 | 29 | 0 | |
Open | Copying this from my post in the ArcGIS Survey123 Questions:---------------------------------------------------------... by EuropaxEarth New Contributor III 1 0 | 1 | 0 | |
Open | Please allow users to customize the Survey123 Mobile App home page with different color themes based on different con... by Jaivik_P New Contributor III 3 2 | 3 | 2 | |
Open | The Num Pad for "numbers" appearance currently defaults to the column width (see below). This can make it very small ... by abureaux MVP Regular Contributor 3 1 | 3 | 1 | |
Open | We would like the ability to upload custom file types to survey attachments. Currently available file types are liste... by ristoulem New Contributor II 0 0 | 0 | 0 | |
Open | This is for the Windows version of the Field App.I really can't count the number of times I have told someone to "Cli... by abureaux MVP Regular Contributor 2 0 | 2 | 0 | |
Open | Add vertical-align property so text can be aligned to the top:As mentioned here. by abureaux MVP Regular Contributor 2 0 | 2 | 0 | |
Open | Can we please improve the ability to expand/collapse group questions in the Survey123 field app? e.g.Have a 'collapse... by ChristopherCounsell MVP Regular Contributor 10 0 | 10 | 0 |
Idea Submission Guidelines
User | Count |
8 | |
5 | |
4 | |
4 | |
3 |
