ArcGIS Survey123 Blog
451
71.1M
277
Under Consideration | Idea: Add Location Profiles as a configuration parameter in Survey123The Problem: You need to apply a datum transform... by ElizabethGreaves New Contributor II 6 3 | 6 | 3 | |
Under Consideration | I feel the addition of a default "Yes/No" question would be quite useful and time saving within the Survey123 web app... by NicolasCelano New Contributor II 8 3 | 8 | 3 | |
Under Consideration | The jr:choice-name function currently returns an error if used in the instance_name field. The instance_name returns ... by Tim-Woodfield Occasional Contributor 6 1 | 6 | 1 | |
Under Consideration | I would like to see the ability to use calculations (specifically sum) on geometry questions in the web interface. I ... by BrandonA_CDPH Occasional Contributor II 0 2 | 0 | 2 | |
Under Consideration | On a custom “thank you screen” defined in Survey123 Connect, it would be very helpful to have the ability to run Java... by kim77 New Contributor II 2 1 | 2 | 1 | |
Under Consideration | I love the new address type question, so much easier to use than a map question when you want to collect the point lo... by JohnNergeBrooklynPark Occasional Contributor II 7 5 | 7 | 5 | |
Under Consideration | Survey123 Connect | Esri can you add the option to auto-magically create a Hosted, View when publishingI usually need... by MichelleWilliamsERM Occasional Contributor III 8 2 | 8 | 2 | |
Under Consideration | I designed two smart forms for my company and leverage the data to be in the dashboards where the end-users could g... by Hussam_AlJabri Occasional Contributor III 30 34 | 30 | 34 | |
Under Consideration | It would be helpful to include information in a webhooks payload that is not part of the feature layer data. For ins... by AndrewBowne Occasional Contributor III 7 2 | 7 | 2 | |
Under Consideration | Users can abandon a survey and discard the data collected. However, when data is primarily collected through repeats... by PhilHickey_ntg New Contributor II 1 5 | 1 | 5 | |
Under Consideration | I would like to see a more visible choice for languages on the Survey123 form. Right now it's really obscure and tiny... by Jen_Zumbado-Hannibal Occasional Contributor 2 9 | 2 | 9 | |
Under Consideration | Currently the deprecation item flag is mostly useless. It can be a deterrent from new users picking a service but the... by stevegourley Occasional Contributor II 11 2 | 11 | 2 | |
Under Consideration | I think a "Dark Theme" button...especially for all apps to the field workers would be optimal in a sunny day. by Anonymous User Not applicable 21 1 | 21 | 1 | |
Under Consideration | My company has published a survey to ArcGIS Online to collect customer interests in our services. We are asking the c... by HannahSturm New Contributor III 71 31 | 71 | 31 | |
Under Consideration | Repeat groups offer a good way to collect soil profile data, as profiles often have differing numbers of horizons and... by CamilleBeasley New Contributor III 135 34 | 135 | 34 |
Idea Submission Guidelines
User | Count |
8 | |
5 | |
4 | |
4 | |
3 |
