ArcGIS Survey123 Blog
449
70.2M
277
Open | It is often required to have a unique id that is not a gloablid structure in reports so they can be linked to the ser... by NicholasMoore Occasional Contributor 2 0 | 2 | 0 | |
Open | I'm a team manager (I have several team managers) and I have a layer where each person can view their own data (we ha... by João_CarlosPinto_Fernandes New Contributor III 0 0 | 0 | 0 | |
Open | The delete button is very close to the back button on the repeat bar. It would be useful to have a pop-up that asks "... by TracyMai New Contributor II 2 2 | 2 | 2 | |
Open | Currently in Connect, when something results in an Error, the error message persists between reloads.That means that ... by abureaux MVP Regular Contributor 3 1 | 3 | 1 | |
Open | Currently, you must submit a survey to any newly published Feature Layer to gain access the "Data" tab of the S123 We... by abureaux MVP Regular Contributor 2 2 | 2 | 2 | |
Open | Currently, when using a hi-precision bluetooth receiver (Trimble R1/R12i and Leica GG04 Basic Plus) on Android OS 13 ... by JoelCusick1 New Contributor III 0 0 | 0 | 0 | |
Open | Could a toggle be created to turn off the default Survey123 camera interface and enable the native device interface i... by HowardBeverly1 New Contributor II 2 0 | 2 | 0 | |
Open | When publishing a survey from Survey123 Connect, there is no option to publish to a specific content folder. When I a... by MFazio New Contributor III 0 1 | 0 | 1 | |
Open | We have a federally standardized form for shoreline cleanup and recovery from oil spills, and maybe there is a way to... by SteveBrewer New Contributor III 0 1 | 0 | 1 | |
Open | I'd like to be able to use a webmap as the map for the data view on the Survey123 website without having to make it a... by DuncanC New Contributor III 0 0 | 0 | 0 | |
Open | I've been using the multiple language functioning in Survey123, and the preview of the survey automatically carries t... by JoshuaChristy New Contributor 0 0 | 0 | 0 | |
Open | It would be helpful to be able to edit and export data from a feature layer pulled into a different organization with... by MeganJames New Contributor II 0 0 | 0 | 0 | |
Open | Very similar to ENH-000119959 that was implemented at 3.13, I am looking to pull a choice list from a json return fro... by Greg_Mattis Occasional Contributor II 8 2 | 8 | 2 | |
Open | We have recently come across an issue trying to use the Survey123 Field App on Windows where the 'Location Inaccessib... by RobertAnderson3 MVP Regular Contributor 4 1 | 4 | 1 | |
Open | I'm working with a Survey123 form where I've configured a "parent" layer to collect the data, and a "child" layer to ... by EricaNova Occasional Contributor 6 0 | 6 | 0 |
Idea Submission Guidelines
User | Count |
9 | |
6 | |
6 | |
5 | |
3 |
