Your observation is correct, the import of an AutoCAD dwg groups data by ArcGIS primatives - ploylines, polygons, etc. It can be tough to find things if you have lines and polygons in the same layer that get sort of separated in the map.
With regards to losing the length attribute - that is one of many dwg elements that are read-only and not stored as an attribute of the object. If that needs to be retained you have 2 ways of going about it 1) save off the layer to a feature class in Pro; 2) Export layer to a shapefile inside AutoCAD Map and add the length attribute to the data collection.
Our road centerlines that I maintain in CAD uses an ObjectData table for things such as road name, maintenance interval, ... so if I want to use in Pro I have to use option 2 and export to a shapefile because Pro does not recognize that data type. Quite frustrating.
The fun is figuring out how to best utilize both software platforms.
Regards,
Tom
