ArcGIS Drone2Map Questions
91
995.6K
317
Open | Hi there,One of the main uses for Drone2Map for my firm is stockpile measurements. Most of the time the stockpiles ar... by AndrewSanford New Contributor II 0 0 | 0 | 0 | |
Open | We are interested in a getting a better handle on the use of ArcGIS Drone2Map in our organization. We have a small po... by PeterKnoop MVP Regular Contributor 0 0 | 0 | 0 | |
Closed | I would like a height above ellipsoid setting when setting up a new project. Our RTK photos reference ellipsoid heigh... by JamesBurton1 Occasional Contributor 2 4 | 2 | 4 | |
Implemented | Please add support for DJI Mavic 3 Enterprise Multispectral UAV drone to supported drones list for Drone2Map Multisp... by Joe_Brickley New Contributor II 0 3 | 0 | 3 | |
Open | Adding the capability to Drone2map of using QR codes for GCP to aid in georefrencing process.If D2M can read QR codes... by BillsWesley New Contributor II 2 0 | 2 | 0 | |
Implemented | It would also be nice if user could add more than one folder when selecting the photos for a project. Sometimes a fl... by frobertsmaf New Contributor III 1 2 | 1 | 2 | |
Implemented | If it is pointed to a folder look for duplicate file names (prefix) that are not true duplicates, for example if they... by frobertsmaf New Contributor III 0 1 | 0 | 1 | |
Implemented | It would be great if Drone2Map could offer other tiling schemas/coordinate systems when using the Share Tab.It is act... by Pål_Herman_Sund Occasional Contributor II 1 5 | 1 | 5 | |
Open | Good afternoon. I am using Drone2Map on a project and was wanting to see A) the individual image extents (not just t... by Jeff_VanEtten Occasional Contributor 1 0 | 1 | 0 | |
Open | In previous releases of Drone2Map we had in the report for Internal camera parameters (IO) both the Initial and Estim... by Pål_Herman_Sund Occasional Contributor II 0 0 | 0 | 0 | |
Needs Clarification | I would like to suggest that the functionality be added to Drone2Map to allow for the direct export of the finished i... by BrigThomas New Contributor III 0 2 | 0 | 2 | |
Implemented | In the new Drone2Map 2022, you can set default coordinate systems for drone images and GCP in the settings, but not f... by BenjaminHaske New Contributor II 0 2 | 0 | 2 | |
Open | Can we get folder access for Drone2Map to access Cloud Storage like OneDrive and GoogleDrive? by TedCronin MVP Honored Contributor 0 1 | 0 | 1 | |
Implemented | It would be nice if you could add DJI P4 Multispectral to your supported drones. The USP would be, that (so far I kno... by Jonas_Agroscope New Contributor II 1 1 | 1 | 1 | |
Open | Skydio is soon to be the #1 US drone manufacturer. Professional pilots are going to need another option if the US gov... by Anonymous User Not applicable 1 2 | 1 | 2 |
Idea Submission Guidelines
