Attempting to apply a layer definition through the flex api to an ArcGISDynamicMapLayer. Target layer is on postgresql/SDE. For some reason, I can use the "date" function successfully, but not the "timestamp" function. Here's the code:var wwaLyr:ArcGISDynamicMapServiceLayer = map.getLayer("WWA") as ArcGISDynamicMapServiceLayer;
var stringDef:String = "beginDate <= timestamp'2010-03-11 19:50:00'"; //This does not work
var stringDef:String = "beginDate <= date'2010-03-11'"; //This works
wwaLyr.layerDefinitions = [stringDef];
wwaLyr.refresh();
Any thoughts on why TIMESTAMP is not working.Thanks,ParksTallahassee
