layerdefinition and timestamp
491
03-15-2011 06:10 AM
ParksCamp
New Contributor III
Attempting to apply a layer definition through the flex api to an ArcGISDynamicMapLayer.  Target layer is on postgresql/SDE.  For some reason, I can use the "date" function successfully, but not the "timestamp" function.  Here's the code:
var wwaLyr:ArcGISDynamicMapServiceLayer = map.getLayer("WWA") as ArcGISDynamicMapServiceLayer;
var stringDef:String = "beginDate <= timestamp'2010-03-11 19:50:00'"; //This does not work
var stringDef:String = "beginDate <= date'2010-03-11'"; //This works
wwaLyr.layerDefinitions = [stringDef];
wwaLyr.refresh();
Any thoughts on why TIMESTAMP is not working.
Parks
Tallahassee
DasaPaddock
What versions of ArcGIS Server and ArcGIS API for Flex are you using?
ParksCamp
New Contributor III
I'm using version 2.2 of the Flex API.  The service I'm consuming is running on ArcGIS Server 9.3.1.
Parks
DasaPaddock
You'll need to be using a ArcGIS Server 10 hosted service since it has added a new syntax for the layerDefs parameter that allows :'s in the definition value. The old syntax uses :'s as a layer id separator.
Reference:
http://help.arcgis.com/en/arcgisserver/10.0/apis/rest/export.html
ParksCamp
New Contributor III
Reference:
Dasa,
Thanks.  That helps.
parks
ParksCamp
New Contributor III
Reference:
FYI,
I was able to find a workaround for this issue by sending the epoch time and using the sql "to_timestamp" function:
var nDate:Date = new Date();
var qTime:Number = nDate.time;
var stringDef:String = "beginDate <= to_timestamp(qTime)";
wwaLyr.refresh();
