Creating multi buffer
592
12-27-2012 07:47 AM
EnriqueIbarra
New Contributor III
I'm using GeometryService to create buffers, I did a query over a Feature Layer in a map service and obtained a collection of features, now a need to draw buffers over these points, but apper that GeometryService don't support make more than once at time, have somebody did it? or ther's another way to make it possible?
The QueryTask
void queryTask_ExecuteCompleted(object sender, QueryEventArgs e)
            foreach (Graphic item in e.FeatureSet.Features)
                Graphic queryGraphic = new Graphic();
                ESRI.ArcGIS.Client.Geometry.MapPoint mapPnt = new MapPoint(item.Geometry.Extent.XMax, item.Geometry.Extent.YMax);
                queryGraphic.Geometry = ESRI.ArcGIS.Client.Bing.Transform.GeographicToWebMercator(mapPnt);
                queryGraphic.Geometry.SpatialReference = sReference;
                BufferParameters bufferParams = new BufferParameters()
                    BufferSpatialReference = new SpatialReference(102100),
                    OutSpatialReference = MapaGM.SpatialReference,
                    Unit = LinearUnit.Meter,
                bufferParams.Distances.Add(1000);
                bufferParams.Features.Add(queryGraphic);
                geometryService.BufferAsync(bufferParams);
And the GeometryService
void geometryService_BufferCompleted(object sender, GraphicsEventArgs e)
            Graphic bufferGraphic = new Graphic();
            bufferGraphic.Geometry = e.Results[0].Geometry;
            bufferGraphic.Symbol = LayoutRoot.Resources["BufferSymbol"] as Symbol;
            bufferGraphic.SetZIndex(1);
            pointAndBufferGraphicsLayer.Graphics.Add(bufferGraphic);
EnriqueIbarra
New Contributor III
You should be able to pass all the features returned from the QueryTask to the Buffer.  The code below works for me
Thanks Terry
well, I used this refference and it works!
http://resources.esri.com/help/9.3/arcgisserver/apis/silverlight/help/Geometry_task.htm
TerryGiles
Occasional Contributor III
void QueryTask_ExecuteCompleted(object sender, QueryEventArgs e)
            FeatureSet fs = e.FeatureSet;
            if (fs.Count() == 0)
                MessageBox.Show("Sorry, no data matches your query.  Please try again", "Query Error", MessageBoxButton.OK);
            else
                BufferParameters buffParam = new BufferParameters() {
                    BufferSpatialReference = _Map.SpatialReference,
                    OutSpatialReference = _Map.SpatialReference
                buffParam.Distances.Add(500);
                buffParam.Features.AddRange(fs.Features);
                GeometryService geoService = new GeometryService("http://<servername>/ArcGIS/rest/services/Geometry/GeometryServer");
                geoService.BufferCompleted += (send,args) =>
                    GraphicsLayer gl = (GraphicsLayer)_Map.Layers[_GraphicsLayer];
                    gl.ClearGraphics();
                    gl.Renderer = LayoutRoot.Resources["SelectRendererPoly"] as IRenderer;  //polygon renderer defined in XAML
                    foreach (var g in args.Results)
                        gl.Graphics.Add(g);
                    gl.Refresh();
                geoService.BufferAsync(buffParam);
EnriqueIbarra
New Contributor III
Thanks Terry
